Hot Bodies D413 1/10 4WD Buggy
#2941
I do know that it is still early but I dont see other company stepping up to make hop up's and small add on's like chassis protectors and aluminum wing mounts. I would Proline,Jconcepts, exotact, and others would have stuff in the works already and at least on pre-order right ???
#2942
Body venting.
I carved out the front left side and rear of the body to get more air flow. I also added these cuts on top of the body. Has anyone else found good venting options. I am one step above blinky mode on timing inside the lrp esc and temps are a concern. I am still in break in mode so I will try running a 7 minute heat to see how it does.
#2952
Using Orion Race Esc blinky / Orion 7.5t with 21 pinion, temps was not an issue after 7 min. I moved to a 5.5t same pinion I thermal at 3-4min. Switched to a 19 pinion did the trick. Coming off at 135 every time.
#2953
#2954
Just a personal experience with a Losi 8ight-E 2.0, I was testing different tires a few weeks ago on an outdoor track. First set was hookin up great, & motor temps were safe. I noticed the second set of tires did not bite as well, checked the temps, 238 degrees fehrenheit !!! Although the car was handling ok, I didn't realize how much I was over spinning the tires on the straights. Put the first set of tires back on, and reduced initial burst in the esc, & temps went below 180.
I didn't realize over spinning the tires would make the motor temps shoot up that high ! Just thought I'd mention it. Hope this helps some one. Food for thought, right ?
#2955
These might work if anyone is looking for wheel hex pin replacements on the D413.
I haven't received my D413 yet, but scteonoffroad took the measurements for me.
http://www.amain.com/product_info.ph...-Pin-15x12mm-6
