Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 05-29-2014, 08:56 PM
  #2851
wrightcs77's Avatar
Trader Rating: 551 (100%+)
Wink
Originally Posted by Speedychris22
Could there be a problem that I can't find?
Simple answer. Gremlins. Did you feed them after midnight?
wrightcs77 is offline
Old 05-29-2014, 09:04 PM
  #2852
Trader Rating: 17 (100%+)
Lasse,
Yeah, I spent time getting the setup perfect and planned to start pushing it hard after that. You got to take advantage of my work straight away you jerk!
I like the ESC in the rear for cleaner wire placement mostly. My car is 45/55 F/R and 50/50
L/R with it there so it also has the advantage of having the weight balance I prefer in my car.
I have a fix for the steering rack slop, I will hook you up.
I will be there sometime tomorrow if all goes well.
AlderBoy is offline
Old 05-29-2014, 09:42 PM
  #2853
kdeleon's Avatar
Anyone else having to really crank their shock collars down to achieve ride height? Mine was set to 22 and yesterday I had to turn it down further to get the same ride height? Also my camber was. Could there be a problem that I can't find?
I have mine set to about 3/4 of the way down in the front. But I do use Xgear springs and not the out of the box ones. If you look at pics of Ty's cars, he also seems to thread them down pretty far.
You do bring up a thought. Anyone consider using truck springs on the front of this car (rear seems fine)? But since we still have more thread left, I didn't think it was critical.
kdeleon is offline
Old 05-29-2014, 10:36 PM
  #2854
gticlay's Avatar
Trader Rating: 14 (100%+)
Hard to tell with the wheels turning left a bit, darn it!!!
gticlay is offline
Old 05-29-2014, 11:36 PM
  #2855
Trader Rating: 21 (100%+)
What 3 hole pistons are you guys running?
masin14 is offline
Old 05-29-2014, 11:54 PM
  #2856
I drilled the blanks that came with the kit. 1.3 3-hole front and rear.
AlderBoy is offline
Old 05-30-2014, 08:11 AM
  #2857
i would have done that too if i had a 1.3mm drill, instead i CA glued a screw into the 4 hole piston
Cygnus X is offline
Old 05-30-2014, 08:46 AM
  #2858
Awesome thanks. I'm up in Chico testing for the right setup, so far so good.
masin14 is offline
Old 05-30-2014, 09:16 AM
  #2859
Proline shock caps? Drove mine for the first time yesterday and i already popped a shock off
Zenbot is offline
Old 05-30-2014, 09:24 AM
  #2860
kdeleon's Avatar
I believe those are custom one offs for Ty. There was rumor that HB would eventually do their own but no date was given.
kdeleon is offline
Old 05-30-2014, 01:14 PM
  #2861
boudin4evr's Avatar
Trader Rating: 18 (100%+)
there is a guy that used AE shocks on his car. I wonder if the shock caps from AE with their standoffs would fit the HB? I'm sure AVID, SCHELLE, EXOTEK, or SOMEBODY will come out with aluminum caps and usual standoffs.
boudin4evr is offline
Old 05-30-2014, 02:43 PM
  #2862
STLNLST's Avatar
Trader Rating: 32 (100%+)
What are you searching for? Everyone should be running your setup in Chico. You already cost me money.......LOL
STLNLST is offline
Old 05-30-2014, 03:54 PM
  #2863
Rybeau40's Avatar
Originally Posted by Rybeau40
How often does the gear oil need changing in the diffs?
Anyone?
Rybeau40 is offline
Old 05-30-2014, 05:08 PM
  #2864
Anyone?
hard to say without knowing how much you drive...i get at least 30+ min of pure driving in 5 days a week (5 battery packs)....if no leaks then i would redo every other month or so
when oil breaks down it gets thinner, so if the car begins to diff out, your either running a leaking diff, or your oil has thinned...either way clean and put some fresh in there
when the diffs have been refilled, and a few packs run through it, take note how much the tire spins when you hold the opposite tire....full, half, third rotation...jot it down somewhere, and check it once in a while
Cygnus X is offline
Old 05-30-2014, 05:11 PM
  #2865
Anyone?
Don't think anyone has had the car long enough to need a diff oil change
Sofa King is offline
