the gm motor thread >
the gm motor thread
the gm motor thread
Old 07-25-2013, 07:24 AM
Bar
Originally Posted by chasingthepack
i had the motor timing on max but then dropped it to 20 deg and it does seem faster as it allows the esc to do the work,your esc settings would give me an idea as the hw and orion are the same esc just branded differently
I run the old HW stock spec speedo, is the orion based on that or the new HW v3/v3.1?
Bar is offline
Old 07-25-2013, 07:42 AM
The Orion was kind of inbetween the two... not quite a v2 and not a v3 kind of a v2.5 if you will.....
Orions software is different too.
Smartypants is offline
Old 07-25-2013, 07:52 AM
Bar
hmm, well i will pm him my settings i use, sounds a bit over geared as well, i have always geared around 6.38 on whatever motor i ran, reedy dynamite, lrp/nosram/ and thunder power
Bar is offline
Old 07-25-2013, 12:45 PM
Running 10.5 last year, with GM motor and speedo we ran some pretty tall gearing everywhere - just one setup sheet I've just looked at I ran 5.9!
That was 10.5, I 'd assume that the 13.5 has similar traits, but I don't know.
MattW is offline
Old 07-26-2013, 03:24 PM
  #20
GM Motors are very good specially if use with GM ESC
which can set to match the track , day, grip, temp, style, etc
they are highly recomended
and if want a bit more go for Plettemberg, , Lehern, Kontronic
All the best
kasiraki is offline
Old 07-26-2013, 11:36 PM
  #21
chasingthepack's Avatar
cheers matt,thats the info i was after,im at 5.85 for aldershot which seems to be perfect now,if the weather holds off tomorrow ill be able to see how i fair against the rest,thats 26/80 so i may drop another tooth on the pinion if it still feels slow on the infield,i may have made the mistake of gearing up for the straight and forgetting about faster accelaration on the infield
chasingthepack is offline
