Engine Modification
Old 06-07-2005, 08:26 AM
Default Engine Modification
Does anyone have an online tutorial about modifying an engine?
performula is offline
Old 06-07-2005, 08:29 AM
For instance - step by step guide, recommended tools, and bits that are needed.
Old 06-07-2005, 10:10 AM
Jye
http://rcnitro.com/rn/articles/ht_tunengine_01.asp
Jye is offline
Old 06-07-2005, 01:07 PM
Tuning I feel I have down, I'm talking about internals.
Old 06-07-2005, 05:16 PM
there was an article in one of the rc magazines a couple of months back but i dont remember when it was. Had a bunch of stuff about moding motors.
ATXPro4 is offline
Old 06-10-2005, 09:50 AM
Modifications are only done to the sleeve and crankshaft, right?
Old 06-10-2005, 09:53 AM
Riketsu's Avatar
Trader Rating: 34 (100%+)
Some also modify the conrod to recieve more RPM but this will shorten the life of the conrod.
Riketsu is offline
Old 06-10-2005, 11:49 AM
What type of bits should be used to grind metal? I will be using a dremel.
Old 06-20-2005, 04:46 PM
Old 06-22-2005, 11:09 AM
RACETEK's Avatar
Trader Rating: 41 (100%+)
Case clearancing, Cutting the crank, piston, sleeve and rod. The only way you can shorten the life of the rod is if you over rev it and break it.
RACETEK is offline
Old 06-22-2005, 11:53 AM
Case clearance? Please explain.
Old 07-08-2005, 08:17 AM
www.affordablenitrotech.com
I found some articles on there, and performed the mods to a couple of engines.
Needless to say, I now have a little O.S. .12 CV that scares me!
jamiekulhanek is offline
Old 07-11-2005, 06:06 PM
Thank you!
