Stripped Screw
Stripped Screw
Hey guys i have an Fk04 and whilts working on it i somehow strupped the screw on the top deck on the front left bulk head, does anyone have any tips on how to get these out without causing damage to the car
try sticking a 5/64 imperial allen driver in there, iirc it is slightly bigger and should fit in there tightly
same if you strip a grub screw in a pinion, use a 1/16 allen driver.
D'oh
Thanks for the heads p dude, but wat if that dont work
Take a dremel with a cutoff wheel and put a slot in the screw head. Then use a small flathead screwdriver to get it out.
-James
-James
you can get those counter drill bit that will grab the screw and unscrew it.
check the sears or home depot.
i think it is call Craftsman 3 pc. Screw-Out™ Damaged Screw Remover Set.
~Ming
~Ming
I had the same problem. I did the dremel trick as said by JamesArluck.
This is very easy, and gives a neat result.
Replace the screws by steel ones made for the original T1. These screws are much harder.
Bye Thomas
~Ming
~Ming
over here in the UK they are called stud extractors.
the threads on them are the wrong way so when you go to unscrew the stuck screw, the stud extractor will actually get even tighter and it will pull the screw out...reeeeealy useful.
you can glue a cheap "L" allen wrench into the screw with CA, let sit overnight, then remove it
I dunno how much room you have... but try removing all the other top deck screws, and then turning the whole topdeck in an effort to get the screw loose.
i was thinking that but i think the top deck is sort of 'sunk in' to the bulkhead..well it certainly was on the evo2 i had, not to sure about the FK04...you could give it a try though, it should work.
Good luck!
KE
