Diffs, shocks and tyres
Hi
I have just finished building my Impulse, and have taken it to the local track. All of the other guys there were taiking about diff oil & tyres etc & completely confused me! I have some questions I am hoping can be answered!
1. What is a 'one way diff' and why and where would you use one?
2. How stiff should the diffs be to turn? Which (front or back) should be stiffer and why?
3. Which tyres are softer 27's or 37's. Should the softer ones go on the back or front?
4. Which shocks should be harder, front or back?
5. My car seems to loose traction at the rear end going into and coming out or corners. What could be the cause?
Sorry for all the questions!
Regards
Russell
Regards
Russell
Re: Diffs, shocks and tyres
Originally posted by russell_gasper
Hi
Hi
Advice (you can take it or leave it. . . ) go to www.mytsn.com and get a standard setup for the Impulse and stick to it. One can be found here: Serpent Site, Foam Setup - Use this for a while and get a feel for the car.
Regards
Russell
Regards
Russell
Russ, you can post your questions on the Impulse at the Serpent Impulse we have at the non hpi forum. It's very active there;
http://www.hpiracing.com/rcforum/sho...&goto=lastpost
To answer your questions, refer below;
1. Please refer here;
http://www.rccaraction.com/articles/oneways.asp
2. If you need lots of steering, front should be less stiff than the rear. Conversely true for an understeer car. Remember, it's all relative. Your driving style will dictate if you like an oversteer or an understeer car. Track style and car setup also dictates this.
3. 27 is softer. Lower the number, the softer the tire. Softer tires usually go at the rear.
4. Like the tires, softer setup for the shocks (i.e. more holes, softer spring and even lower shock oil weights) are used in the rear.
5. The answer would lie in the car setup.
You could post your car setup in the forum above and the guys over there can scrutinise your car setup and give suggestions to improve your car handling.
Is your car the normal Streetspec or the PRO kit?
