Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
#1232
Rear hub and front arms...la272...
I tried diff gear ... 3k-5k ... I'm using red and white slipper ... better front or back track to medium low grip ?? Recommended to increase oil diff ??
#1233
Alright guys... So I'm trying to decide on a new wheeler. Been running the ZX5 for probably about 3 years and it's served me well, but it's time to get something newer/more competitive. I'm looking for some feedback...
For those of you who ran the ZX5 and have the ZX6 now, what do you feel the improvements were/are? Is it more durable? Better steering? If so, does it have better steering into the corner, middle, exit? I see that there are still problems with getting ride height low enough which is worrying.
So what's your honest opinion?
#1236
with arms rb6 lowers the very ZX6 ... than arms dishes I changed ball end shocks from S to M ... to have the same excursion frame height of 21mm .. nobody uses pad slipper red ??
#1237
I had the ZX5 for over a year. The ZX6 gets low. I'm running at 20mm and can go down more. Durable way beyond what I expected. I'm not a great driver and all I have had to replace is one front shock shaft (tried to stuff the car into the end of the pipe) and the front right inner hinge pin and arm landing on the pipe where it was nailed down. The steering rack is much better and the steering is improved everywhere. My setup I have more entry steering. I just killed my low profile servo. It really needs to be a full size as much as I touch the pipe. That's all I've done since I got the car in August. If you like your 5 you'll love the 6!
#1238
Ran the new car today,
Put about 9-12 runs on it for practice and some tweaking.
Love the car. For sure better than the zx5 I had, but still have a few things to rework. Car doesn't seem to like a ton of droop. Uses a lot less on the front form the zx5 I had. Seemed a bit weird but worked well. Should be good once I get it all dialed in.
#1239
One other thing,
I was looking over the setup sheets for the car and noticed that when it comes to the caster block on the front, there's two ball stud holes you can use, but the setup sheets don't specify which one is used. Looking at a few pics some guys are running the rearward ball stud hole on the caster block.
Other than that I think I found a couple setup issues I have that made the car react weird when more droop was used on the front. Something else for me to play with the next time I get out for a practice day.
#1240
What do you mean exactly by arms skimmed 2 mm forward ? You reduce the wheelbase by 2 mm, right ?
#1242
Hi guys.
one question.
Can be used the new internal gears of LA50 set in rb6 gear diffs?
one question.
