Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread >
Like Tree35Likes
    Hide Wikipost
Old 01-24-2018, 07:02 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: alex4r
Kyosho ZX6.6 New Parts (* = required to update ZX6 to ZX6.6 platform)
LA359B - Center Mount Set (ZX6.6)*
LA375 - Center Diff. Gear Set(ZX6.6)*
LA375-01 - Center Diff. Gear Case Set(ZX6.6)
LA375-78 - Spur Gear(48P-78T/ZX6.6)
LA376 - Center Drive Shaft (71.5/ZX6.6)*
LA377 - Center Drive Shaft (79.5/ZX6.6)* (x2)
LA378 - Center Drive Shaft (88/ZX6.6)*
LA379 - Joint Cup Cover (ZX6/ZX6.6)*
LAW54B-01 - HD Chassis*
LA355B - Side guard set*
UM713B - Rear Arms (from RB6)*
UM561 - Outer rear hinge pins*
LA236-12B - 1.2mm Front sway bar*
LA351B 4-hole front shock tower*
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals
Lazer ZX6.6
Lazer ZX6
After Market Bodies
JConcepts Silencer
Weight Reduction options for 13.5 Class
Chassis:
UMW711B - Carbon composite rear arms
LAW60 - Carbon composite front upper bulkhead
LAW61 - Carbon composite rear upper bulkhead
LAW52 - Carbon composite front chassis brace
LAW53 - Carbon composite rear chassis brace
LA209HB - Carbon composite gear boxes (pinion bearing retainer & upper gearbox half only, lower half not compatible/saves 4.6g total)
Driveline:
LA211B - Plastic drive cups for center drive shafts coming out of front & rear gear boxes (requires drilling two holes for set screws to secure LA379)
TFW001 - Aluminum blade style outdrives (for ball diff/requires TF013)
LA202 - Aluminum pinion shafts (for ball diff)
TFW126 - VVC outdrives (for gear diff - front/rear/center)
TFW008 - VVC cross pins (for gear diff - front/rear/center)
Misc:
LAB06LW - LW Blade body
SK0402 - Ti screw set (Available at Lunsfordracing.com)
PTK-T-2111 - Ti screw set (cheaper, slightly less durable option)
LNS7765 - Ti ball studs
LNS2688 - Ti Turnbuckles
LNS36107 - Ti Turnbuckles (super duty)
W0201H - Hard anodized lower shock balls
1-N3024A-R - Aluminum M3x2.4 nuts (for shock standoffs)
1-N3033NA-R - Aluminum M3x3.3 locknuts
Print Wikipost
Old 08-30-2014, 07:09 AM
  #871
Originally Posted by K_King
Yeah I do like the shock mounting locations. I also prefer the sway bar mount. The downside is they are more expensive. I like the stock arms better though. I think for 4W you need that rear to be a little flatter through corners.
Yeah the RB6 arms seem to give a lot more steering so I don't think necessary on the ZX6...mid corner of power especially... Kit arms gives in my opinion more consistent steering through the whole turn...
In the UK a lot of people on the RB6 run these arms for that reason alone WITH the new inside hole...I guess that's because we all run on high grip astro..
I will be trying however the new hole on the RB6 arms on my RB6..
njc11 is offline
Old 08-30-2014, 10:15 PM
  #872
Rybeau40's Avatar
Anyone have a chart for the various suspension holders front and back and what type of degrees each combo entails?
Rybeau40 is offline
Old 08-30-2014, 11:39 PM
  #873
Have a look on petitrc under ZX6 and you will see the rear ones.. Then look under RB6 for what I'm sure will be the front ones for the ZX6... ( same inserts etc used)
njc11 is offline
Old 08-31-2014, 05:41 AM
  #874
Rybeau40's Avatar
Yea, looked there already, but the link for the chart does not work on the zx-6 sus holders amd RB-6 only has links for it's rear holders, which are different. Can't believe the manual doesn't have a chart.
Rybeau40 is offline
Old 08-31-2014, 06:27 AM
  #875
Trader Rating: 71 (100%+)
Yes, should be in the manual - but it's not. I asked about this when I first built my car too.
http://www.petitrc.com/setup/kyosho/...olderChart.pdf
That will work for F/R inserts.
Basically allows you to not only change toe-in (or sweep in the front), but also track width depending on which inserts you use to achieve said toe in.
Notice on most setups the front will be C/C, which map out to zero degree toe, using the chart. And the rear will be some combination to achieve toe-in.
negatv1 is offline
Old 08-31-2014, 06:43 AM
  #876
Rybeau40's Avatar
What handling change occurs going from 3.0 to 3.5? Thanks for that chart.
Rybeau40 is offline
Old 08-31-2014, 06:49 AM
  #877
Some are trying it, I like the stock arms or NCG arms if you want the RB6 style.
Ive had a look and measured different holes on the different wishbones, NCG, KIT and RB6 they all seem the same to me??
njc11 is offline
Old 08-31-2014, 06:52 AM
  #878
Adds more toe-in same as any other car - More forward traction, at cost of some rear side bite. Run less toe-in when the grip is high to free the car up/rotate better in corners.
negatv1 is offline
Old 08-31-2014, 05:07 PM
  #879
hay guys just wondering how you are attaching the rear sway bar when using the RB6 rear arms
rcmad2700 is offline
Old 08-31-2014, 05:49 PM
  #880
Trader Rating: 357 (100%+)
If you have the kit you're fine. If you're trying to piece it together you'll need those. There's velvet coated ones as well but I can't find those either lol
Thanks. I'm starting my build tomorrow, doing everything except diffs. The Law50 will be here this week.
jmoneym is offline
Old 08-31-2014, 05:50 PM
  #881
teeforb's Avatar
Trader Rating: 94 (100%+)
What do I suppose to shim for the front center dog bone? Mines is coming out. I see nothing in the instructions of shimming
teeforb is offline
Old 08-31-2014, 06:31 PM
  #882
cnelson3's Avatar
Trader Rating: 66 (100%+)
I'm curious, why gear diffs? My standard ball diffs are solid and handling great. I check them between runs just to make sure they are tight but I'm not yet seeing the need.
cnelson3 is offline
Old 08-31-2014, 06:41 PM
  #883
vr6cj's Avatar
Trader Rating: 124 (100%+)
High bite sugar tracks will benefit with gear diff due to the added traction and then there's the maintence part.
vr6cj is offline
Old 08-31-2014, 06:57 PM
  #884
RB6 MM rear sway bar kit has everything you need.
negatv1 is offline
Old 08-31-2014, 07:04 PM
  #885
For me it's a maintenance thing. Lazy racer here
jmoneym is offline
