Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread >
Like Tree35Likes
    Hide Wikipost
Old 01-24-2018, 07:02 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: alex4r
Kyosho ZX6.6 New Parts (* = required to update ZX6 to ZX6.6 platform)
LA359B - Center Mount Set (ZX6.6)*
LA375 - Center Diff. Gear Set(ZX6.6)*
LA375-01 - Center Diff. Gear Case Set(ZX6.6)
LA375-78 - Spur Gear(48P-78T/ZX6.6)
LA376 - Center Drive Shaft (71.5/ZX6.6)*
LA377 - Center Drive Shaft (79.5/ZX6.6)* (x2)
LA378 - Center Drive Shaft (88/ZX6.6)*
LA379 - Joint Cup Cover (ZX6/ZX6.6)*
LAW54B-01 - HD Chassis*
LA355B - Side guard set*
UM713B - Rear Arms (from RB6)*
UM561 - Outer rear hinge pins*
LA236-12B - 1.2mm Front sway bar*
LA351B 4-hole front shock tower*
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals
Lazer ZX6.6
Lazer ZX6
After Market Bodies
JConcepts Silencer
Weight Reduction options for 13.5 Class
Chassis:
UMW711B - Carbon composite rear arms
LAW60 - Carbon composite front upper bulkhead
LAW61 - Carbon composite rear upper bulkhead
LAW52 - Carbon composite front chassis brace
LAW53 - Carbon composite rear chassis brace
LA209HB - Carbon composite gear boxes (pinion bearing retainer & upper gearbox half only, lower half not compatible/saves 4.6g total)
Driveline:
LA211B - Plastic drive cups for center drive shafts coming out of front & rear gear boxes (requires drilling two holes for set screws to secure LA379)
TFW001 - Aluminum blade style outdrives (for ball diff/requires TF013)
LA202 - Aluminum pinion shafts (for ball diff)
TFW126 - VVC outdrives (for gear diff - front/rear/center)
TFW008 - VVC cross pins (for gear diff - front/rear/center)
Misc:
LAB06LW - LW Blade body
SK0402 - Ti screw set (Available at Lunsfordracing.com)
PTK-T-2111 - Ti screw set (cheaper, slightly less durable option)
LNS7765 - Ti ball studs
LNS2688 - Ti Turnbuckles
LNS36107 - Ti Turnbuckles (super duty)
W0201H - Hard anodized lower shock balls
1-N3024A-R - Aluminum M3x2.4 nuts (for shock standoffs)
1-N3033NA-R - Aluminum M3x3.3 locknuts
Print Wikipost
Old 08-18-2014, 10:30 PM
  #766
mourinho's Avatar
Trader Rating: 46 (100%+)
Originally Posted by JarrodP
I just emailed proshop about them. No reply yet.
They're on eBay for 100 bucks each.
Yeah I think je models is the seller, they are way overpriced with the pound to aud conversion. Should be a fair bit cheaper from Japan or even amain when they get them.
mourinho is offline
Old 08-19-2014, 03:44 AM
  #767
Does anyone know when amain will have stock??
Egress is offline
Old 08-19-2014, 03:55 AM
  #768
kenny lutz's Avatar
Trader Rating: 38 (100%+)
Je models is where I ordered them from
kenny lutz is offline
Old 08-19-2014, 04:30 AM
  #769
Trader Rating: 71 (100%+)
Originally Posted by kenny lutz
Got gear diffs on the way anyone have any oil suggestions I was thinking 15 and 7 or 5
Got a set too (euro model in fr ~$92 after conversion plus shipping) and I'm going to start at 7/3, and tweak as needed.
negatv1 is offline
Old 08-19-2014, 04:37 AM
  #770
kenny lutz's Avatar
I thought about starting there but I need to get rid of off power steering after I added droop in the car.the layout we have is real bump with no good downsides so I had to add some droop yo get it more planted and land better.
Old 08-19-2014, 04:38 AM
  #771
JarrodP's Avatar
Proshop have them for cheaper then I expected.
JarrodP is offline
Old 08-19-2014, 05:35 AM
  #772
kenny lutz's Avatar
How much are they there?
Old 08-19-2014, 05:49 AM
  #773
JarrodP's Avatar
About 120 a set aussie dollar. 60 each
JarrodP is offline
Old 08-19-2014, 05:54 AM
  #774
JarrodP's Avatar
And that's posted I should add.
JarrodP is offline
Old 08-19-2014, 07:08 AM
  #775
kenny lutz's Avatar
That's cheap. Can't wait to get mine. I tried to order from there but didn't get any email response and wouldn't let me pick any us cities.
Old 08-19-2014, 10:48 AM
  #776
Trader Rating: 13 (100%+)
Can't wait to try mine out tomorrow!
Attached Thumbnails Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread-003.jpg   Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread-001.jpg
R.M.S is offline
Old 08-19-2014, 01:22 PM
  #777
Speed Freak RC's Avatar
Man Schwabie! Looks killer. I have been looking at this car or the B44.3 for this winter.
Speed Freak RC is offline
Old 08-19-2014, 03:55 PM
  #778
Thanks Rob, Ill let you know how it drives!
R.M.S is offline
Old 08-20-2014, 07:09 AM
  #779
Guys, who knows when a Main will have the gear diffs in stock?
Egress is offline
Old 08-20-2014, 10:17 AM
  #780
Probably only Amain.
negatv1 is offline
