Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread >
Like Tree35Likes
    Hide Wikipost
Old 01-24-2018, 07:02 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: alex4r
Kyosho ZX6.6 New Parts (* = required to update ZX6 to ZX6.6 platform)
LA359B - Center Mount Set (ZX6.6)*
LA375 - Center Diff. Gear Set(ZX6.6)*
LA375-01 - Center Diff. Gear Case Set(ZX6.6)
LA375-78 - Spur Gear(48P-78T/ZX6.6)
LA376 - Center Drive Shaft (71.5/ZX6.6)*
LA377 - Center Drive Shaft (79.5/ZX6.6)* (x2)
LA378 - Center Drive Shaft (88/ZX6.6)*
LA379 - Joint Cup Cover (ZX6/ZX6.6)*
LAW54B-01 - HD Chassis*
LA355B - Side guard set*
UM713B - Rear Arms (from RB6)*
UM561 - Outer rear hinge pins*
LA236-12B - 1.2mm Front sway bar*
LA351B 4-hole front shock tower*
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals
Lazer ZX6.6
Lazer ZX6
After Market Bodies
JConcepts Silencer
Weight Reduction options for 13.5 Class
Chassis:
UMW711B - Carbon composite rear arms
LAW60 - Carbon composite front upper bulkhead
LAW61 - Carbon composite rear upper bulkhead
LAW52 - Carbon composite front chassis brace
LAW53 - Carbon composite rear chassis brace
LA209HB - Carbon composite gear boxes (pinion bearing retainer & upper gearbox half only, lower half not compatible/saves 4.6g total)
Driveline:
LA211B - Plastic drive cups for center drive shafts coming out of front & rear gear boxes (requires drilling two holes for set screws to secure LA379)
TFW001 - Aluminum blade style outdrives (for ball diff/requires TF013)
LA202 - Aluminum pinion shafts (for ball diff)
TFW126 - VVC outdrives (for gear diff - front/rear/center)
TFW008 - VVC cross pins (for gear diff - front/rear/center)
Misc:
LAB06LW - LW Blade body
SK0402 - Ti screw set (Available at Lunsfordracing.com)
PTK-T-2111 - Ti screw set (cheaper, slightly less durable option)
LNS7765 - Ti ball studs
LNS2688 - Ti Turnbuckles
LNS36107 - Ti Turnbuckles (super duty)
W0201H - Hard anodized lower shock balls
1-N3024A-R - Aluminum M3x2.4 nuts (for shock standoffs)
1-N3033NA-R - Aluminum M3x3.3 locknuts
Print Wikipost
Old 08-05-2014, 08:49 AM
  #676
Trader Rating: 71 (100%+)
Another question regarding the suspension arm inserts- For the front, does it follow the same chart as the rear? Looks like could be used to adjust track width as well?
http://www.petitrc.com/setup/kyosho/...olderChart.pdf
negatv1 is offline
Old 08-05-2014, 01:58 PM
  #677
Does anyone have a good base setup for a loose, rough outdoor track?
rcracer007 is offline
Old 08-05-2014, 02:56 PM
  #678
mourinho's Avatar
Trader Rating: 46 (100%+)
Yes it applies to the front also, each step adjusts track width.
mourinho is offline
Old 08-05-2014, 06:26 PM
  #679
Trader Rating: 57 (97%+)
My kit comes tomorrow, any tips before I start the build that might be noted for this particular kit? My MP9e went together flawlessly.
CaseyDDR is offline
Old 08-05-2014, 08:31 PM
  #680
Holmberg418's Avatar
Put both cup joint sponge pads up front. One on the slipper assembly and the other on the drive gear shaft.
Holmberg418 is offline
Old 08-06-2014, 12:25 AM
  #681
Why would you suggest this? Is the front center dogbone too loose or is it just because the car is more quiet then?
Egress is offline
Old 08-06-2014, 06:37 AM
  #682
Trader Rating: 19 (100%+)
Originally Posted by kenny lutz
I went back to the small ends with flat arms. right now my setup is 42.5 t front 32.5 rear 2 hole 1.6 pistons. hubs middle in the rear. orange front gold rear springs. tight front diff medium tight rear. 2 mm inside rear at bulkhead all the way inside and 3rd farthest hole on the hub. pink sway bar front and rear. I'm going to go to 37.5 front 30 rear as the car is a little stiff but feel really good overall. its starting to come around and drive very consistent and easy to drive. I'm c in on the rear front hanger and rear rear f out. then c out in the front front and rear. this is rear motor shorty with esc in the front. now I'm going to try servo transponder and receiver all on the same side with the motor and esc on the left with the esc in the rear to see what it does to the handling. seems to add a little more weight to the rear so should plant the car more but think it might be to much possibly.
Thanks for the help. I'll give that a try.
Cfconcrete is offline
Old 08-06-2014, 07:03 AM
  #683
Trader Rating: 68 (100%+)
Kenny what type of surface do u run on?
Speedychris22 is offline
Old 08-06-2014, 08:00 AM
  #684
lewis4x4's Avatar
Question: Since CC IN and CC OUT both equal a "0", what would be the difference? Another words, both fronts holders with C IN or both with C OUT? Thanks...
lewis4x4 is offline
Old 08-06-2014, 08:04 AM
  #685
The track width would be narrower/wider, yet still have 0 degrees of sweep.
negatv1 is offline
Old 08-06-2014, 09:56 AM
  #686
Jochim_18's Avatar
What's your shock setup? Seems like with rear motor configuration the rear end of the car just slaps like crazy I went to 4 different piston and oil setup with no luck however the buggy is on rails but it just bottoms out no matter what shock setup I did.
Jochim_18 is offline
Old 08-06-2014, 05:47 PM
  #687
jwcobra03's Avatar
Trader Rating: 69 (100%+)
What pinion to run with stock spur and a 6.5 motor?
jwcobra03 is offline
Old 08-06-2014, 07:22 PM
  #688
Small indoor track? 18t
Big out door track? 20t
With the orion vst2 6.5t no timing or boost no temp issues and plenty fast
Tom87 is offline
Old 08-07-2014, 02:18 AM
  #689
kenny lutz's Avatar
Trader Rating: 38 (100%+)
The track is medium bit clay that is farely bumpy.
kenny lutz is offline
Old 08-07-2014, 04:06 AM
  #690
Zylux's Avatar
Finished my ZX6. Just need to cut out a fresh wing and set the camber, toe, ride height etc.
There is only one problem... I was aiming for 1613 grams and overachieved apparently. Total weight is 1564 grams. Looks like I didn't need to buy the SMC 3500mAh packs and modify the battery posts! Not sure whether I'll just put in the SMC 4600 batteries (about 60g heavier) or add some brass/copper weights.
Zylux is offline
