Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread >
Like Tree35Likes
    Hide Wikipost
Old 01-24-2018, 07:02 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: alex4r
Kyosho ZX6.6 New Parts (* = required to update ZX6 to ZX6.6 platform)
LA359B - Center Mount Set (ZX6.6)*
LA375 - Center Diff. Gear Set(ZX6.6)*
LA375-01 - Center Diff. Gear Case Set(ZX6.6)
LA375-78 - Spur Gear(48P-78T/ZX6.6)
LA376 - Center Drive Shaft (71.5/ZX6.6)*
LA377 - Center Drive Shaft (79.5/ZX6.6)* (x2)
LA378 - Center Drive Shaft (88/ZX6.6)*
LA379 - Joint Cup Cover (ZX6/ZX6.6)*
LAW54B-01 - HD Chassis*
LA355B - Side guard set*
UM713B - Rear Arms (from RB6)*
UM561 - Outer rear hinge pins*
LA236-12B - 1.2mm Front sway bar*
LA351B 4-hole front shock tower*
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals
Lazer ZX6.6
Lazer ZX6
After Market Bodies
JConcepts Silencer
Weight Reduction options for 13.5 Class
Chassis:
UMW711B - Carbon composite rear arms
LAW60 - Carbon composite front upper bulkhead
LAW61 - Carbon composite rear upper bulkhead
LAW52 - Carbon composite front chassis brace
LAW53 - Carbon composite rear chassis brace
LA209HB - Carbon composite gear boxes (pinion bearing retainer & upper gearbox half only, lower half not compatible/saves 4.6g total)
Driveline:
LA211B - Plastic drive cups for center drive shafts coming out of front & rear gear boxes (requires drilling two holes for set screws to secure LA379)
TFW001 - Aluminum blade style outdrives (for ball diff/requires TF013)
LA202 - Aluminum pinion shafts (for ball diff)
TFW126 - VVC outdrives (for gear diff - front/rear/center)
TFW008 - VVC cross pins (for gear diff - front/rear/center)
Misc:
LAB06LW - LW Blade body
SK0402 - Ti screw set (Available at Lunsfordracing.com)
PTK-T-2111 - Ti screw set (cheaper, slightly less durable option)
LNS7765 - Ti ball studs
LNS2688 - Ti Turnbuckles
LNS36107 - Ti Turnbuckles (super duty)
W0201H - Hard anodized lower shock balls
1-N3024A-R - Aluminum M3x2.4 nuts (for shock standoffs)
1-N3033NA-R - Aluminum M3x3.3 locknuts
Print Wikipost
Old 06-30-2014, 02:31 AM
  #436
jelly's Avatar
Originally Posted by jelly
hmmm no setup. and the manual doesn't explain which battery layout to use.
setup is in the manual
at a glance:
1.6*2 pistons
gold springs front+rear
front susp holder B-in/B-in
rear susp holder D-in/D-out
find out rest in build
jelly is offline
Old 06-30-2014, 03:08 AM
  #437
KalEl63's Avatar
Trader Rating: 13 (100%+)
Mine is in Melbourne as well hopefully get it in the next day or two.
Here is the kit set up I put toghter quickly while going thru the manual (not sure it helps)
File Type: pdf
KalEl63 is offline
Old 06-30-2014, 03:15 AM
  #438
Zylux's Avatar
Originally Posted by vikingen
starting build Friday. will try to remember to take pics and weigh bits
Awesome. Thanks mate!
Zylux is offline
Old 06-30-2014, 03:23 AM
  #439
Jpm1's Avatar
I understand that the manual has all the position etc so it is basically a kit setup but it doesn't outline what track conditions are or shock oils I don't believe?
Jpm1 is offline
Old 06-30-2014, 05:00 AM
  #440
Trader Rating: 68 (100%+)
I also don't understand what b in b in means on the front end? How much kick up?
Speedychris22 is offline
Old 06-30-2014, 12:22 PM
  #441
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
B/in B/in is just track width id assume kick up will be 25 but not sure on that.
As for the battery placement not sure why everyone is so tore up over this.
saddle packs will IMO give most rear traction less steering
shorty with motor in the rear would be the next best thing in traction to the saddle packs
motor front and shorty rear will give you the most steering.
these are just assumptions and I would think they would be pretty close to right.
Ultraspeed84 is offline
Old 06-30-2014, 07:20 PM
  #442
KalEl63's Avatar
Mine arrived first thing this morning now if the SC6 kit arrives today it will be Xmas in July
Most likely won't get to start building it until the weekend though
KalEl63 is offline
Old 06-30-2014, 08:10 PM
  #443
Oh come on Dave let's see some pics!!
  #444
vikingen's Avatar
Trader Rating: 29 (100%+)
time to update that sig of yours mate
vikingen is offline
Old 06-30-2014, 08:31 PM
  #445
JarrodP's Avatar
Mine still saying it's in Melbourne. Dammit
My tools and work table are ready.. Haha
JarrodP is offline
Old 07-01-2014, 01:40 AM
  #446
KalEl63's Avatar
If I get a chance I will start it tonight and post some pics up
Updated
Hopefully you get yours tomorrow.
I'm surprised you didn't get yours today since both of ours had to go interstate from Melbourne
KalEl63 is offline
Old 07-01-2014, 01:44 AM
  #447
vikingen's Avatar
Friday Night Football is likely to delay my build until the weekend. My team is playing and a friend is coming over to help empty my beer fridge and eat pizza
Rather not build it after a few lol
vikingen is offline
Old 07-01-2014, 02:03 AM
  #448
TLRMAN's Avatar
Opened my Bmax4 111 fix kit to confirm everything was in the box to stop the slop in the shocks, the loose spur assy and the axle pins that break and the wheel nuts that fall off, and you wouldn't believe it I must have got the limited release kit with bonus parts cos there was a body and wing in there, can't wait to build and run it and finally finish a race
TLRMAN is offline
Old 07-01-2014, 03:53 AM
  #449
KalEl63's Avatar
Ok here are some build pics and about as far as I can go tonight.
Lovin’ the build so far but mind you I have all my Kyosho cars
KalEl63 is offline
Old 07-01-2014, 04:14 PM
  #450
JarrodP's Avatar
Great pics mate.
JarrodP is offline
