Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
#1727
My ZX5 dirt car I am going to try 7k/5k since the 2 indoor clay tracks near me are med-high grip. My buddy who is a Serpent driver is running that in his snake. 5k/3k sounds like low-med grip but I am basing that on my 8th scale experience.
#1730
I did however order a pair of these:
http://www3.towerhobbies.com/cgi-bin...?&I=LXCBYH&P=7
At $1.99 each why not?
#1731
Need gearing setup for 13.5 please and thank you
#1732
I did the same thing. Be careful opening up the ball ends however. Too much and your set screw won't bite anymore.
Well seems that in less than 4 weeks we finally will have the option for thicker anti roll bars directly from Kyosho. My guess is that the set includes 2x 1.8mm and 2x 2.0mm bar. Might be wrong though....
Oh and they also provide the stabilizer end with the 2.1mm hole drilled. No more customizing.
Just wanted to buy some piano wire but after experiencing the pain it was to bent a 2.0mm wire for my D413 i guess i wait for Kyosho to do it machined!
Also finally there are damper stays made from carbon by Kyosho!
#1733
#1735
center diff
lets hope they get that center diff out when they said they would, at first i was told February and now I am being told March. I hope this isnt a on going thing with kyosho because for me a center diff is key for my staying with the kit, if not I would just stay with my xb4.
#1736
Trader Rating: 89 (100%+)
#1738
hey guys, i need a little help with understanding the setup on the zx6. what i am looking for is a chart that explains what the pills for the suspension do. I obviously know what they do....lol.. just need help understanding what each does for the car. I am also looking for what the spacers do for the suspension blocks. I found something on petitrc.com but that confused me even more. Thanks in advance
#1739
http://site.petitrc.com/setup/kyosho...olderChart.pdf
There is no other way to explain it really. That chart does it. The hard part to grasp sometimes is that you can achieve a particular toe setting with multiple different combinations.
