Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread >
Like Tree35Likes
    Hide Wikipost
Old 01-24-2018, 07:02 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: alex4r
Kyosho ZX6.6 New Parts (* = required to update ZX6 to ZX6.6 platform)
LA359B - Center Mount Set (ZX6.6)*
LA375 - Center Diff. Gear Set(ZX6.6)*
LA375-01 - Center Diff. Gear Case Set(ZX6.6)
LA375-78 - Spur Gear(48P-78T/ZX6.6)
LA376 - Center Drive Shaft (71.5/ZX6.6)*
LA377 - Center Drive Shaft (79.5/ZX6.6)* (x2)
LA378 - Center Drive Shaft (88/ZX6.6)*
LA379 - Joint Cup Cover (ZX6/ZX6.6)*
LAW54B-01 - HD Chassis*
LA355B - Side guard set*
UM713B - Rear Arms (from RB6)*
UM561 - Outer rear hinge pins*
LA236-12B - 1.2mm Front sway bar*
LA351B 4-hole front shock tower*
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals
Lazer ZX6.6
Lazer ZX6
After Market Bodies
JConcepts Silencer
Weight Reduction options for 13.5 Class
Chassis:
UMW711B - Carbon composite rear arms
LAW60 - Carbon composite front upper bulkhead
LAW61 - Carbon composite rear upper bulkhead
LAW52 - Carbon composite front chassis brace
LAW53 - Carbon composite rear chassis brace
LA209HB - Carbon composite gear boxes (pinion bearing retainer & upper gearbox half only, lower half not compatible/saves 4.6g total)
Driveline:
LA211B - Plastic drive cups for center drive shafts coming out of front & rear gear boxes (requires drilling two holes for set screws to secure LA379)
TFW001 - Aluminum blade style outdrives (for ball diff/requires TF013)
LA202 - Aluminum pinion shafts (for ball diff)
TFW126 - VVC outdrives (for gear diff - front/rear/center)
TFW008 - VVC cross pins (for gear diff - front/rear/center)
Misc:
LAB06LW - LW Blade body
SK0402 - Ti screw set (Available at Lunsfordracing.com)
PTK-T-2111 - Ti screw set (cheaper, slightly less durable option)
LNS7765 - Ti ball studs
LNS2688 - Ti Turnbuckles
LNS36107 - Ti Turnbuckles (super duty)
W0201H - Hard anodized lower shock balls
1-N3024A-R - Aluminum M3x2.4 nuts (for shock standoffs)
1-N3033NA-R - Aluminum M3x3.3 locknuts
Print Wikipost
Old 09-17-2015, 07:10 PM
  #1576
stiltskin's Avatar
Trader Rating: 103 (100%+)
Car is built and ready to go. First laps tomorrow night and then racing saturday. Can't wait to put it on the track.
stiltskin is offline
Old 10-07-2015, 11:37 PM
  #1577
Trader Rating: 90 (100%+)
Crickets! I'd love to see World's pics of the zx6 layouts from our drivers. I checked neobuggy without any luck.
Kuya_Kimo is offline
Old 10-08-2015, 03:58 AM
  #1578
Trader Rating: 68 (100%+)
I redid the car with the motor forward, wow car def easier to drive. A slight push onpower but def better then the rear motor setup.
Speedychris22 is offline
Old 10-08-2015, 05:42 AM
  #1579
Gayosaka's Avatar
http://www.neobuggy.net/2015/10/08/u...usuke-sugiura/
Gayosaka is offline
Old 10-08-2015, 10:16 PM
  #1580
Thanks! NB Posted after I went to bed...
I see a new center diff without slipper, using the new HD chassis, and a shaved v2 rear hub.
Do ya'll see something different?
Old 10-09-2015, 03:36 AM
  #1581
I don't see a center diff in his car. Thats the same slipper we have. i think he shaved the rear hubs for clearance issues being that the car is probably at 18 or 19 ride height. The only thing I see different is the one piece servo mount, which I think is from the touring car. Looks like no special parts that we can't already buy.
potatobed409 is offline
Old 10-09-2015, 06:35 AM
  #1582
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Here are a few more pics from Red RC
Kraig is offline
Old 10-11-2015, 05:09 AM
  #1583
Guys, is this gunmetal aluminum one piece servo mount that matsukura and sugiura used at the worlds already available? Do you know where to get them?
Egress is offline
Old 10-11-2015, 01:11 PM
  #1584
rpboggs1's Avatar
Trader Rating: 19 (100%+)
Can we adjust the ball diffs like we can on the rb6? Do we need a special tool to hit the screw?
rpboggs1 is offline
Old 10-11-2015, 05:53 PM
  #1585
Super Moderator
Kraig's Avatar
You need a 2mm wrench. Pop off the ball cup and remove the dog bone. Insert the wrench and tighten or loosen as needed.
Kraig is offline
Old 10-11-2015, 06:56 PM
  #1586
rpboggs1's Avatar
Thanks for the reply! Can we use the TLR diff tool so we don't need to pop off ball cups? Or perhaps swap out the screw for an RB6 one with the slotted head?
rpboggs1 is offline
Old 10-11-2015, 07:38 PM
  #1587
Super Moderator
Kraig's Avatar
I don't know how deep theirs goes into the diff to give you an answer. I suspect you could do the same thing with a "L" shaped allen wrench.
If I remember correctly, the diff out drive doesn't have a hole in it like the other vehicles do. The other reason why I don't think that will work is the size of the head, it might be to big.
Kraig is offline
Old 10-14-2015, 02:53 AM
  #1588
Anyone has any information on this floating servo mount? I know it seems the same design as the red touring car ones but is there a number for it in gunmetal?
Egress is offline
Old 10-16-2015, 07:14 AM
  #1589
Trader Rating: 42 (100%+)
Is the JConcepts Silencer the only other body avaliable? The Kyosho body is nice looking, but just checking if anything else was released.
IMO the JC body is ugly as hell.
Nexus is offline
Old 10-16-2015, 03:43 PM
  #1590
Trader Rating: 36 (100%+)
Any info if they make center differential of this buggy?
raved007 is offline
