2013 LAS VEGAS INTERNATIONAL INDOOR CHAMPIONSHIPS "IIC" W/SCOTTY ERNST
#946
#947
Thank you Randy for providing this system as it made for a great class. Also, we should put a tutorial together for next year so you don't have to explain to people that their cars aren't quite as fast as others because their battery voltage was lower or they weren't on the throttle near as long.
#948
The RPM curve will climb at a mostly steady rate and then rolls off at the top. If you are seeing it at the steady rate when you hit the end of the straight you were likely overgeared. Mine started to round off at the end which indicated I was most likely in the ball park. I remember a peak of 17600 and was able to hold 17400 through out the race. This was with a 4.55 gear ratio.
#950
Moderator
Edit: Waiting for the new Hotwire!
#951
New Hotwire Shortly.. We had to finish up a few things for the RSX. Final version is being tested by team currently and should be posted this week assuming all is good
#952
Does this mean I need to buy a new Hotwire or just the software in new and I can keep my old Hotwire?
#953
Moderator
Old hotwire, new software
#956
Trader Rating: 89 (100%+)
2014
Any 2014 info????? is there a thread yet ?
#960
Weight for Spec
Lets get the weight for the SpecGT class right up front this year. Please don't change it while we are in tech again this year.
