New Novak Brusless System
#76
5800 adjustable profile rate comparisons
Hello Charlie
Thanks for fixing my 5800 a few months ago.........I agree that the 5800
is about a "hot 19T".......can you confirm that the different profile settings -
1-6 change the output rating, spool up, or what - what are we really adjusting with the different profiles?
bill
bill
#77
relax guys....
it will come someday, as for now I'm just glad to see Novak release thier mod esc. This is a leap in mainstream US brushless and that's a good thing. As far as adjusting the power/rpm, I think Novak's doing it right. How would you ever moditor it for racing. Having a stock profile blue light like the SS esc helps. The big power cap? No problem, better performance. Don't we all want that anyway?
#78
Originally Posted by newracer
I am sure the technology is a little different since the Novak is sensored but Castle Creations accomplished this without increasing the size of the esc and all the data is transferred through the rx plug on the esc. Just FYI.
when you say novak is sensored, does it mean the others use a different technology? whats the advantage of novak being sensored?
#79
The Castle Creations I posted about is a non-sensor system for aircraft. Sesnored systems, like Novak and LRP, are supposed to be better for cars, the sensor makes for better throttle control.
#80
Sensored systems like the Novak detects exactly where the armature is inside to stop that annoying cogging like sensorless systems.
Sean
Sean
#81
Sensorless have more complex software for running the motor, sensored based systems are the easy way out as you don't need as good a software to run the motor. Sensor based systems should therefore be cheaper then a sensorless system. My U-Force 75 is sensorless and has no cogging with my Plettenberg motor!! The more poles a motor has, the easier it is for a sensorless system to run them. The Novak motors are only 2 pole, wheras my Plettenberg is 4 pole. For some reason the U-Force hates the Novak motor. I haven't run any other 2 pole motors to compare, but I've heard the winding used is a big problem too. The ROAR and IFMAR rules allow sensorless esc's, but the motor specs will mean a sensorless esc is unlikely to run properly.
#82
are all brushless motors and/or their ESC's made equal? unlike brushed motors that can be "tweaked" for additional performance?
what is the limiting factor in making a faster Brushless motor? the reason i'm asking is becuase with these new high capacity batteries, and improvements in brushed motor technology, its now a common sight to run 6, 7 turn motors, whereas two years back when 8's and 9' turn motors where the common motor of choice, brushless technology was at around 12turn... i'm just curiuos as to when could brushless technology be at par with regards speed and power of brushed motors...
i think brusless motors have great advantages over their brushed counterparts; however, in my opinion, no matter the advantages, speed is still my number 1 concern and priority... that's why unless brusless motors can really compete with their brushed counterparts, im still reluctant to get 1... BUT... im really dying to try 1 out, i wish there was a demo unit we could try out...
#83
#84
Good to see you have taken some interest in Brushless Systems highwayman. I'm also glad to see so many "newcomers" take notice of Brushless Technology... even Nitro guys are starting to realize it's many benefits and potential! Just wait until they combine Li-Po batts with Brushless Technology. Speeds and Run Time will be absolutely unreal!
Hey TRINITY..... Pay Back is such a Wonderful Thing!
#86
looks like the same size as the older version...
... on another note, i have those novak platinum batteries and they are very very good...
stealth : yeah, when that time comes, who knows, maybe EP cars can compete with nitro cars...
#87
That's sweet...
can't wait! Looks like there is a new poll type connection for the motor. Much easier to mount the wires to the motor.
#88
esc
programmer via usb
esc
programmer via usb
Now that's what I wanna see...
#89
Danjoy25 - Great Pic! On my computer I rotated it and zoomed in on the ESC (sorry, couldn't save it soomed in) and it clearly shows it has a HUGE Black Capacitor right under the top-deck. Any space saved by the GTB ESC being close to the size of a GTX is now lost because of this.
One positive thing is it does come with it's own fan which at least looks like it is specifically made for the GTB. For all my SS5800s I had to buy Reedy's replacement Heatsink Motor Fan to keep my temps in check for Off-Road use. Strategic placement is definitely key! Hope Novak starts to sell these fans separetley as well cause they do breakdown every now and then (especially when racing in the Dirt).
Novak is on the ball... they do have the fans available separately! Bravo!
