New Novak Brusless System
#1621
R/C Tech Elite Member
Originally Posted by pheyhoe
Ok, just like to clear this up. It is the motor that overheats isnt it?
#1622
And a shame i cant see the lights from the drivers stand! lol.
Thanks anyway.
I just found that i was geared at 10.18. which is pretty low
going to try 11.5 or something once i find out what the biggest spur that will fit on my BD is.
Thanks anyway.
#1623
Thanks anyway.
Thanks anyway.
116 tooth @ 64pitch is the biggest you put on the BD.
#1624
Problems w/ my gtb.
I think it needs to go to service, but maybe I am missing something.
The motor will not run when I pull the trigger, I can spin the rotor and the motor will run, but once i let off and try to press the gas again, nothing!
I have replaced the motor between 3.5 and 4.5, i have switched between the sinitered and regular rotors, I replaced the capacitor and I even tried a new reciever. I had to switch back to brushed motor/esc to run my races today.
Nothing happened to cause the issue, I just went to run in my first race and it would not work, fresh pack, tried both 4200 and 3800 batteries, w/ and w/o servo hooked up. I had previously ran 3 or 4 times in practice during the morning w/ no issues.
If anyone has had this problem b4, please let me know.
Otherwise it looks like i have to ship it back
I also tried to reset the speedcontrol, but that did nothing to help the problem
#1625
Originally Posted by dbmartin
Problems w/ my gtb.
db, it seems that your gtb has problems with the fets..... it happened to my first one.... just send it to Novak. in any case, send an email to charlie telling your problem, he will tell you better what to do...
cheers,
#1626
Hi guys, Tried the new 13.5 today in a race and just didn't like the performance. I usually run in the top 3 in stock A main but this thing was getting me farther and farther behind and put me in the B main I was also having issues with cogging or thermaling.
I tried the same gear ratio I was running with a Quantum2/CO27 combo and also tried going up and down 2 or 3 teeth. But nothing seemed to help.
To me this is definately slower than stock motors! Maybe I should sell it.
#1627
I know this is lazy and i could probably look through the thread but i need a gearing start point for a 4.5R in a BD running rubber on carpet on a BIG track, talking two basketball court size but with some twisty bits. Should i go with the 10-10.5 suggested? ran 10.25 in practise as a shake down at smaller club and seemed ok. have seen setup sheets with 8.5fdr though spose i could just wait and see if pushing the limit is a good idea!
#1628
#1629
Super Moderator
#1630
#1631
It is definitely NOT slower than a brushed stock, liten to what James is saying....
I usually run a 40-45mm rollout with a Monster Stock in my 12th scale, I'm running 55mm rollout with the 13.5... I could definitely go up a few more teeth....
#1632
Originally Posted by Marcos.J
9.75 fdr is a good ratio for the 4.5. I usually run around a 10.0 depending on the track surface temp. If is really hot out Il run a 10.65 FDR and never had any thermal issues
#1633
Super Moderator
I imagined you could push past the recommended wussy fdr's. believe me when i say i'll be wearing 6 layers of clothing and keeping my batteries in my pockets it'll be that cold where i'm going! might try 10 in practise and work down! thanks
#1634
Ok ill give it another try....
Question: when people say "Go up a few teeth" are they refering to the FDR by lowering the amount of teeth on the pinion gear?
I always used a gear chart to determine where I should be with my gearing and the term go up a gear escapes me now.
If I add a bigger pinion then my FDR will lower
If I go to a smaller pinion then it will raise correct?
Thanks for your help guys.
#1635
Super Moderator
