corner weight??
Old 05-25-2013, 02:26 AM
chasingthepack's Avatar
Default corner weight??
hi all,i have some scales to measure the corner weights ,what i want to know is do i just adjust each corner using the spring collars,the ride height was 5.5 f and 5.8 rear,but since getting all four corners the same(20 gms heavier on the front)the ride height has changed from 5.5 to 6 on one side at the front and 6.0 to 6.2 on the rear but only on one side,how much does it matter and should i be adding weight to get all corners the same?
the car already weighs 1410gms so reluctant to add more weight
so whats more important having a level chassis or the corners weighing the same?cheers guys
chasingthepack is offline
Old 05-25-2013, 06:26 AM
Most important is an even ride height. The fronts need to be the same and the rears need to be the same but front and rear can be different. then balance the car left to right by adding, removing, or shifting weight. very important to have an equal left right balance. front to rear is not as important. I only use scales to identify a chassis tweak. You will see severe differences in weights if the chassis is tweaked.
6376vette is offline
Old 05-25-2013, 06:53 AM
wingracer's Avatar
Trader Rating: 24 (100%+)
If just one side is high, lower that side and corner weight should stay the same.
wingracer is offline
Old 05-25-2013, 03:18 PM
Mr RCTech's Avatar
First scale on a level surface.
Both crossweights need to be the same AFTER car balance has be set.
Mr RCTech is offline
Old 05-26-2013, 06:08 AM
Timbo99's Avatar
Trader Rating: 14 (94%+)
Default Rollcentre
Any weight you add to the car should be down the centre.
It's basic physics.
Imagine two axis,a Y and X axis,one is straight up the centre of the car,the X across the car.
Your cars weight in all four corners will always differ when the car is being driven,but,as long as it can ROLL from side to side,the car will feel great.
Adding weights to the edge of the chassis is creating a ballast effect,the car HAS to expend more energy hauling that weight around a corner,whereas in the centre it's all evenly distributed.
You will be creating a pendulum effect and will upset the whole dynamically set ups made to the car.
I really advise you try it though,put ALL the weights on the corners and see what the car does.
Do this when your on the track on your own as it won't be pretty.lol.
Hope this helps mate,corner weights aren't critical on a moving object.
Tim
Timbo99 is offline
Old 05-26-2013, 06:10 AM
Timbo99's Avatar
+1
Timbo99 is offline
Old 05-26-2013, 07:52 AM
It's basic physics.
Tim
Adding weight down the center will only work if the car has a good left to right balance to begin with. you have to have a good left to right balance or the car will handle differently in left turns and right turns. if the balance is off the corner weight will never be right.
Agree that corner weights are not critical. balance is far more important.
Old 05-26-2013, 07:55 AM
wingracer's Avatar
Yes balance is important but so is cross. Try driving a car with 55% cross sometime and tell me what you think. I promise you will hate it
Old 05-26-2013, 08:45 AM
I agree completely. In my experience the cross weight changes because of a chassis tweak. if the car is balanced it will usually have a cross weight that is pretty close. if you are out of balance then you won't get the cross weight right without completely screwing up ride heights or other adjustments that will have an even worse effect on the handling. I guess I should have said to balance first then cross weigh the chassis and make any fine adjustments.
Old 05-26-2013, 11:09 AM
thanks for all the replys,much appreciated
