Intellect Battery 3800
#916
Company Representative
If you want the fastest cells then buy IBs they have proven to be faster. The 3600s will perform about the same as the 3800s and you will save some money.
If you use a low peak detect and follow the reccomended care for them the IB cells are holding up real well.
#917
yes
#918
Hi Danny
Thanks for the info
Where can I find the care info for IB3600's? I have found IB3800 care.
I will be using a new APS updated firmware charger so I believe with the temp sensor and peak detects this should not be a problem. My concerns were with long term performace and storage in cold conditions (car/garage) during the non race days till the next charge cycles
Thanks for the info
#920
Originally Posted by Danny/SMC
How much time are the packs taking to charge in seconds when your cycling them ? It should be around 2500 seconds.
When you raced them what did you do after you run them ?
#921
Everything seems o.k. on your end. I'm assuming there is no air blowing o the packs when your cycling them ? If you haven't trayed them after use and let them stored like that and you don't dump them on the track then your runtime should be higher.
I cycled a 6 cell pack with 414 seconds on the labels for 5 straight days at 35 amps and on the 5th day it was 412 seconds on my GFX.
#922
Danny,
Do you have any thoughts on the Tekin tray. I'm interested on how 3800's will react to being left on a tray at .5 volt per cell for more than a day vs. storing at .9/5.4 per cell/pack.
#924
#925
NiMh cells don't like to be deep discharged under high loads. So dumping your pack on the track will most likely remove some runtime. If you do dump a pack on the track and had no choice because you were in a race bring back your car in the pits and put back 100 seconds of charge back in the pack and let it rest with this charge back in. This could help.
I'm sure your packs are fine as runtime isn't really a problem in most classes.
#926
Thank you Danny/SMC.
#929
The IB3800s were not submitted in time for them to be approved in Europe. Only the IB3600s and VTEC3700s are legal. We had 2 drivers at the Orion Speedweeks who used IB3600s with good results and we will have 5 drivers attending the DHI cup with IB3600s.
Expect to lose 50-100 seconds of runtime by keeping the voltage down on IB cells.
#930
Originally Posted by XrayFK
I know the IB are supposed to be kept to 0.9v/cell, but has anyone tested the results as to traying them and leaving them at 0v? Would this simply kill the cells or take off runtime? Thanks.
