Factory Team TC4 from RCX
I think this car is underweight, I see nothing wrong with those adapters.
but otherwise, this car doesn´t look like an associated one.
They need to dump the cheap leaky plastic shock caps, or do they like sending business to Yokomo for their bladder caps?
Thepitcrew - I told them they should put diaphragms in their shocks when the first released the tc3 and they claimed their daft foam was a better volume compensation system
#20
Does any know what diffs they are using. The pic of the rear end show an cut out in the material. Are they stell or Aluminum cut out maybe?
#21
31062 TC4 Lightened Steel Diff Outdrives pr $19.99
You need the ntc3 rings, inner bearing/bushings and the main bearrings to use them though . I think your best bet is to buy 2 complete ntc3 diffs and 4 bearings. A friend has them and they don't look a great deal lighter. I don't know why they didn't machined even more weight off them like the old MIP lightweight diff halves.
Check out the Xray diffs for a proper lightweight steal diff, shame on you AE
#22
Well this thing can't be under weight. The Pro4 is under weight and it does not have all that baggage of Aluminum posts or Aluminum camber link mounts and it has a smaller top plate and the lightened steel diff is not light. If this car is under weight it by a few grams.
#23
Oh ok, Have not seen those around here. Thanks
#24
"You need the ntc3 rings, inner bearing/bushings and the main bearrings to use them though . I think your best bet is to buy 2 complete ntc3 diffs and 4 bearings."
I have used the lightened steel unit as a front diff (until going to a spool), and all I needed to make them work was the 3926 TC3 diff rebuild kit with the parts from the original TC4 diff tossed in. Use the 3918 instructions that are on the AE site for the assembly order as it is backwards from the standard TC4 diff.
#25
#26
The Ft TC4 will come with the option of building composite or steel diffs.
#27
Originally Posted by NVisible
whats with the scabbed on Antenna mount?
Well, if you look closely, this 'scabbed on antenna mount' allows you to remove ALL the electronics from the car, including the antenna and mount, without pulling the antenna WIRE from the tube. You won't have to feed the wire up the tube anymore..it's a one piece unit.
The car is just slightly under weight as it sits...not by much though.
The cost to tool a new diff housing top as opposed to an adapter is HUGE! Plus, we need to continue using the current diff housings for RTR's and Team kits.
#28
How funny, Associated years back was always on the cutting edge of technology with it's car designs, like the ahead of it's time TC-3...... then they finaly introduce the TC-4 after many years of "supposed" research.....and It ends up having the battery moved twords the centerline of the car at the "exact" same location as the BMI TC-3 that's been out for well over a year......now it has even more borrowed traits from the BMI line of kits......like Seaball said...talk about struggling to keep up......several year old technology at work,all the way around.....Dont' get me wrong Im not saying associated's new car wont work....ofcourse it will,the BMI TC-3 works great
#29
Not to start a pissing match, but MOST (if not all) the AE Team Drivers started milling their chassis' LONG ago to move the battery further in. BMI, IRS, and other companies, started coming out with TC3/TC4 chassis conversions and added this as the next 'evolution'. Doesn't it make sense that, once WE come out with a Factory Team version of a proven car (that just happens to have a CF chassis) that we incorporate these 'Team Driver mods' to our version??? If we didn't, everyone would be complaining that it DIDN'T have these mods. This is not a who-did-what-first-and-copies-someone-else....this is a do-what-works in the next generation of the car.
#30
AE when is the belt TC BARRY BAKER car coming out? maybe HUDY could make it L8
