F201
#1322
try the eagle tyre warmers. Get them overseas and they should be just under $100 AUD. They have a digital readout and have adjustable temperatures front and rear
#1323
Any manufacturer tire warmers work fine. The more expensive ones have temp control.
#1325
Since you are online, you can visit some websites for best pricing. There are some online hobby shops in your part of the world, I know, I almost ordered some stuff from a shop in Sydney. Search the web, you'll find something.
#1326
Gearing?
Which is better for Tamiya Type T or Type R motors, the Stock Kit Gears and the Speedtuned Gear Set? Thanks
#1327
I got mine from andy at hobbymania. Most of the shops in HK or Japan will sell them
#1328
setup
hey guys, does anybody have a setup for medium to loose
bite for these cars i have 2 and starting to race them a little
so anyhelp would be awesome
thanks mike
[email protected]
thanks mike
[email protected]
#1329
Shock Pistons?
In David Jun's setup, what pistons did he use 1 hole or 3 holes? Thanks.
#1330
If I remember what he did, I believe it was the three hole pistons. That was awhile ago. His article may still be in the Tamiya USA website.
#1331
Here is part of the page...
Set up used for the F201:
Enlarged View
Front Suspension
Camber: -1 deg.
Toe: 0 deg.
Ride Height: 4mm
Pillow Ball Gap Upper: 4mm
Pillow Ball Gap Lower: 5mm
Shock Length: 58mm
Down Travel: 5mm
Suspension Rod Length: 49.7mm
Oil: 3000 weight w/one black o-ring added above the bladder.
Spring: Firm (olive)
Preload Clip: None
Rocker Arm: Aluminum w/2mm spacer on shock side.
Differential: Lightweight diff set (very tight)
*Fiberglass stabilizer plate is not used.
*Pillow ball gap is the distance between the knuckle arm and the suspension arm.
*Rod measurements and shock lengths are from end to end and can vary depending on assembly.
*Overall ride height will be higher initially but will settle after shocks are cycled through driving.
*Down travel measured with the tires removed and the chassis on a tweak board. Measurement is the distance between the board and the bottom of the knuckle arm. (set camber before checking down travel)
Rear Suspension
Camber: -1 deg.
Toe: 2 deg. In (toe rod length 51.3mm)
Ride Height: 3.5mm
Pillow Ball Gap Upper: 3.8mm
Shock Length: 80.7mm
Down Travel: 5mm
Suspension Rod Length: 48.3mm
Oil: 3000 weight
Spring: Soft (black)
Preload Clip: 3mm
Rocker Arm: Aluminum w/no spacers
Differential: Lightweight diff set (tight but free)
#1332
If he's running 3000 weight diff oil, then he's running the stock "nail" pistons. This was probably before Tamiya released the teflon pistons.
#1333
Just to check with you guys here.
I have a VERY NEW F201 for sale.
Its built but never run before.
I plan to sell it for very cheap (read at a lost).
Still better to concentrate on TC.
If anyone interested pls give me a quote with a price.
Sorry to disturb this thread
#1334
F1 Racing in Southern California
Hi all, especially those here in CA--
Just a reminder that regular 2nd and 4th Tuesday racing is held at SoCal raceway; I think the 5-week month of March may have thrown some folks off the scent!
Next event will be April 27th; the racing evening starts at 7 PM. Hope to see the "regulars" and some new faces as well.
Terry V.
Terry V.
#1335
Can't make it on Tues Terry, I have to baby sit.
