F201
#1112
My carpet set-up for Ozite carpet....
Williams body and Ferrari wings. the front wing nose has been cut down
to lower the profile.
P2K Pro motor
The upgrades listed are all Tamiya parts
High Speed gear set, metal motor guard, metal 6mm wheel nuts, upgraded turnbuckles,
light weight diff set,
Futaba FM radio, GMiV12 speed control,
Front:
Ennenti 26mm foams 45 shore
6mm ride height
190mm track width
1.5 deg negative camber
0 deg toe-out
Tamiya 1 hole piston
Trinity 45 weight oil
No droop limiters
Tamiya olive spring
Metal locker arms, normal orientation
Upgraded metal shocks, adjusted to ride height
Rear:
Ennenti 30mm foams 40 shore
5mm ride height
195mm track width
2 deg negative camber
2 deg toe-in
No droop limiters
Tamiya olive spring
Wing in up-force positon
P2K Pro motor
Front:
6mm ride height
190mm track width
0 deg toe-out
No droop limiters
Tamiya olive spring
Rear:
5mm ride height
195mm track width
2 deg toe-in
No droop limiters
Tamiya olive spring
#1113
Originally posted by TimPotter
back into F1 again..... What are the "MUST " haves for the 201.
That site has all the answers you are looking for luke!
#1116
The car will have much more steering with the Type A's than with Pit Meds, so that setup should work well if you turn down your dualrate. You might also try olive springs up front to tame it down a little or put a couple 0.3mm shims or even a black o-ring over the front shock shafts before you assemble them in the shock bodies to reduce droop slightly.
#1117
I wish there was carpet around here so that I can try those setups.
#1118
We'll save room on the drivers stand for you here in NorCal
#1119
#1121
Originally posted by RC Driver Gary
What different way can you put the lockers on?
#1123
Originally posted by rc-zombies
Drive up to Stockton ... if Randman from San Diego can make it...so can you...
#1125
Wing question
Which wing position should i use for a low grip carpet track? I've never tried the lower position before and I wonder if it could help adding more traction on the rear.
do you guys treat all 4 tires??? ( I think I will use some Corally)?
Thanks.
Gilles.
Thanks.
Gilles.
