Sakura Zero S or the Spec-R S1
Problem is the local hobby shop stocks parts for the higher end TCs like Xray and AE but I'm not looking to drop $400 on a TC to run in the RCGT class which is why I'm looking at the above two cars. If I go with the Sakura I'll grab the motor mount, thanks for the tip.
Reading about both cars this seems to be the case, for the $20 price difference it seems the Spec-R might be the better choice. Is there anything you'd absolutely recommend getting for the Spec-R out of the box? It comes with threaded shocks correct?
I have both and like using each depending on the race. I use the sakura in vta and the spec r for tc. about the only option you might want for the spec r is to get the sway bar kit and thats about it. But they both are good cars and drive about the same to me anyway. You can"t go wrong with either car it just comes down to what you want to spend really.
The S1 has a front spool, threaded shocks and the motor mount has a third motor hole so when using large pinions you do not have to go through the spur to tighten the motor. I run one in 17.5 blinky as well as Canadian VTA which is 21.5 blinky. The car runs great in both classes.
Looking at the manual of the Spec-R car on page 19, there's an indication that a part isn't included. Is it the wheels or the Hex adapters they're talking about?
http://www.tqrcracing.com/forum/file...ion_Manual.pdf
Good car out of the box, ton of upgrades if you so desire. Xray and Tamiya bits fit too, so there are other options. Things I'd really recommend would be alloy hexes as mentioned above, Tamiya ballcups and some flanged bearings for the layshaft. Few cheap upgrades that are worth it for sure.
Might be easier to refer to step 36, battery installation page.
The wheels, it comes with hexes, they're just plastic. I'd recommend buying some alloy clamping ones as it's easy to ruin the plastic ones, and easy to lose the pins.
Hmm, on the link I listed page 19 is showing, what I believe to be, the hex adapters as not being included. You have to look at the printed page 19 in the manual not page 19 according to the PDF reader, they're a page off.
