1/10 Servos Question. MKS & Hitec
Hi all,
I got a question regarding my setup for my V1 RRR. Its probably a bit late as ive already purchased the servos but just want to make sure. If its no good ill replace them.
Steering servo
MKS HV-787P Titanium Gear Servo
6.85kg (95oz) and 0.041 @ 6v
Throttle/Brake Servo
Hitec HS-7966HB
7.99kg (111oz) and 0.08 @ 6v
Both servos are coreless i believe.
Anyway id just like an idea if this is setup is good enough to compete with on an ameature level for on-road as i usally play 1/8 off road.
Steering servo
Hitec HS-7966HB
I still run this car in and use Futaba 9452 which are about 9kg and .1 to 60 degrees.
I use the same in both throttle and steering with no trouble (have raced this class over 10 years now). Yours sound similar so you should be fine....just try them and see.
The only difference I have found with less expensive servos is that they dont centre as well....not so much a problem in the throttle, but irritating in the steering...
Kudos for the effort up front, hope you enjoy the traction
