3 Racing Sakura XI Sport
#571
Got in the mail today! Ordered from dinball on ebay. Took about a week.
If you are in the U.S. you could of ordered it from TQ Racing and got it much sooner!
http://www.tqrcracing.com/shop/produ....asp?p_id=6163
#572
Picking up a Sakura XI soon to start racing in 17.5 sportsman. Besides getting full ball bearings, would upgrading to the floating servo mount make a huge difference? Which other extra parts would be useful when i start racing? Stabilizer set? Front end parts?
Going to run it with a Futaba 3pl, FEETTECH lowlrofile servo and sp reventon r+V3 mmm 17.5 motor. Hopefully i'll be set for a while. And all for about $300.
- Pinion: 39, 40 & 41
- Spur: 70, 71 & 72
#574
Kimbrough 48p 66T (aka: team associated 66) is a perfect fit onto the Xi pulley.
The swaybars work very well also - either the Zero set, or the Xi set.
If the swaybars and a kimbrough 66t are not properly working, something may be out of whack.
#576
#577
Anything else I should upgrade? Any benefit using SSK drive shaft?
If I would to install anti-roll bars, will it be sufficient just install on the front?
#579
Took the car to my local hobby shop and people were all over my car haha.
#580
Is it having SSK shaft for the front is sufficient? What about the rear shaft?
#581
SSK is not a necessary piece, but it will help if you are already consistent and fast, and run with a thick front diff/spool. The standard cvd's in the rear are more than enough, as they won't reach a steep enough angle to justify the use of an SSK-type shaft.
#582
Has anyone tried the graphite chassis? I would like to save some weight and this will do more than I need.
#583
Regarding the anti-roll bars, will it be useful or sufficient to install only the front?
#585
hi guys, I just bit the bullet and bought myself a xi, this will be my first rc ever, and I have a quick question: I plan to use the xi as a drift car to play with my nephew, after much reading I realize that I should put in a one way diff for the front, and that is where I have a problem, 3racing SAK-U315 (ultimate) vs SAK-59 (zero-s), they both say it is compatible with the xi, so is the diff the same? the zero-s one looks like it has a gear on it, where the ultimate does not...can anyone help me out? thanks!
