3 Racing Sakura XI Sport >
Like Tree344Likes
Old 06-04-2014, 06:29 PM
  #376
I'm a complete noob at all this, so forgive my ignorance. I just recently built this car and am going to be running it on a fairly tight carpet track. What ballpark should I be in as far as gearing goes? I will be running it in the gt class(21.5 motor). Any help would be greatly appreciated. Any other tips also welcome.
tapornap113 is offline
Old 06-04-2014, 07:49 PM
  #377
moparSRT's Avatar
start somewhere between 3.5-4fdr depending on track size, check your motor temp every couple laps and gear/time from there.
you will need a spur around 66T 48p or 88T in 64p
moparSRT is offline
Old 06-05-2014, 02:48 AM
  #378
Thanks. I have a Tekin RS esc/motor, which has built in temperature monitoring. Is it accurate enough to go by, or do I need another means of measuring it? What should be the max motor temp.?
Old 06-05-2014, 05:48 AM
  #379
moparSRT's Avatar
keep it safe at 160F or less
dont rely on the esc for temp monitoring, use a temp gun
moparSRT is offline
Old 06-05-2014, 02:52 PM
  #380
Trader Rating: 61 (94%+)
What sway bars are u guys running
tcb22185 is offline
Old 06-05-2014, 02:56 PM
  #381
moparSRT's Avatar
1.5mm front, nothing rear on asphalt
moparSRT is offline
Old 06-06-2014, 05:02 AM
  #382
I must say for the $109.00 this kit cost it is very well designed. Stuff goes togather very very well. They did a fine job on this one..
tcb22185 is offline
Old 06-07-2014, 12:30 PM
  #383
Just to ask, are these compatible with my sakura Xi sport ?
http://os.3racing.hk/products.php?products_key=4738
I just want to buy them (and the floating servo mount)
coderzone77 is offline
Old 06-07-2014, 03:16 PM
  #384
Nego's Avatar
Trader Rating: 107 (100%+)
yes they are i have them both on my xi.
Nego is offline
Old 06-09-2014, 01:55 AM
  #385
Just ordered the 5mm Hexagons for the wheels and the Alluminium floating servo mount
Some other needed upgrades in your opinion ?
Old 06-09-2014, 07:12 AM
  #386
What is a nice inexpensive servo?
ttsquirrel is offline
Old 06-09-2014, 08:04 AM
  #387
MD
MD's Avatar
Trader Rating: 136 (100%+)
Here's a good low profile servo.
http://www.valuehobby.com/radio-syst...hd-1207tg.html
MD is offline
Old 06-09-2014, 06:55 PM
  #388
Angry
ok so i bought the 88t 64p gear but now the 19t center pulley doesnt fit on it!!! it will not fit flush.
so the question i have is should i cut the center pulley around the screw holes to make it fit flush or grind the spur gear to make it fit flush??
the other problem i have is my dremal is not here so i cant fit it tonight..
tts
Old 06-09-2014, 07:05 PM
  #389
ok just making sure i got this right.. im trying to get fdr and the only thing i find in the manual is that gear ratio is 2:1 (38T/19T).
what is the internal ratio that i use when i am determining fdr. i have a 88 spur and 48 pinion. so 88 divide by 48 times what??
the zero s had a internal of 1.9 but i changed it to 2.0. what does the xi have??
thanks and sorry for the newb q's
tts
Old 06-09-2014, 07:09 PM
  #390
moparSRT's Avatar
tts
yes, just trim it around the screw holes ... I just used some body scissors.
tts
internal ratio on XI Sport is 2:1
so
88 / 48 X 2 = 3.66 FDR
moparSRT is offline
