TLR 8IGHT E 3.0 THREAD
#2643
#2644
#2646
so u let the pin 3518 rest against the rubber O ring ? I cant see how it would last and seal W/O the washer ?
#2650
#2651
Anyone else had issues with stripping plastic spurs? I dont want to go to a metal one for the added rotational weight and most of all them just being so loud. Sounds like I may just have to suck it up and go with a metal spur though. Just didnt know if I was the only one.
#2654
Losi 8ight 3.0 servo question
Hey guys I just got a 8ight-e 3.0 RTR. First time out I burnt up my servo, no surprise right?? Well anyways I bought a savox sw-0231mg. First off it doesn't fit very well. The holes to mount didn't line up and now that it is installed the steering linkage doesn't sit flat anymore and the servo horn that came with it is junk. So what I am wondering is if anyone else uses this servo, if so what horn are you using? I would love an aluminum one.
Also I am curious what servo and horns you guys are using that fit and work well. If I need to get another one to fit properly I am willing to do so.
Thanks guys.
Thanks guys.
#2655
The sw-0231mg is bigger than the servos usually used which is probably causing your fitment issues
sw-0231mg Dimensions (mm): 41.8x20.2x42.9
SC-1258TG Case Size (LxWxH): 40.3x20x37.2mm
The arm you want for a savox servo is http://www.amain.com/losi-aluminum-servo-arm-fut/p13553
