TLR 8IGHT E 3.0 THREAD
#2147
Anyone post a link to the 8hole shock piston. 1.3 for front
#2148
R/C Tech Elite Member
#2149
I can use them for front and rear?
#2151
#2153
Nice! I've always been a Tekin guy in 1/8 scale. How does this match up to the RX8 Gen 2 IYO? Tuning, performance,feel/response, etc...? Considering possibly you've never owned one... What have you researched or heard?
#2154
It looks solid and with the optional sensor port you have that option for wiring. Programming box is costly and you have to power down every time you change each profile step. (unless they have changed that on the box?). No question they are a quality product.
I will stick with the Tekin. More power easier to program no external caps and the switch is not the program button. And 90 dollars cheaper.
Tekin......
http://www.amain.com/product_info.ph...-Brushless-ESC
Specifications.
Controls: Forward/Brake/Reverse
Input Voltage: 2S-6S LiPo
BEC: 6.0V / 7.4V 7 Amps
Motor Limit Brushless Mode: No Limit
Motor Limit Brushed Fwd Only Mode: No Limit
Motor Limit Brushed Fwd/Rev Mode: No Limit
Max Current: 220 Amps per phase
Timing Profiles: 7 choices (on board)
Brushed Modes: Fwd Only, Fwd/Rev, Rev Delay
Brushless Modes: Fwd Only, Fwd/Rev, Rev Delay
Dimensions: 1.5x2.2x1.4in (38x55.8x25.5mm)
Weight: 2.7oz / 76.5g
Orion.......
http://www.amain.com/product_info.ph...-ESC-180A-2-4S
Specifications:
BEC Voltage: Adjustable 6V or 7.2V 5A max
Continuous Maximum Current: 180A
Input Voltage: 7.4V – 14.8V 2S-4S LiPo/LiFe
Momentary Peak Current: 860A
Full On Resistance: 0.00028mohm
Compatible Motors: Max 2700kV
Function Modes: Forward/Brake, Forward/Brake/Reverse, Forward/Reverse (Crawler)
Programmable: Yes
Speed Control Type: Brushless - Sensored and Sensorless
Tekin......
Specifications.
Orion.......
Specifications:
Programmable: Yes
#2156
you may want to pop the seal on remaining bearings to insure there is in fact grease in them.
dont use the supplied shock oils
#2158
- Front hinge pins,
- Front shock shafts (maybe also for rear),
- Spare front and rear suspension arms,
- Rear hub carriers, if you do not upgrade to the alu part,
- A complete set of bearings in case you have one failing,
And last, but not least, get the 45T metal spur gear to replace the 43T plastic spur gear. This would maybe even be a first priority.
Or maybe just bring happy and joy to your LHS, go buy a complete kit as a spare
