Schumacher Mi5
#706
So far so good with my Mi5. No breaks no issues! apart from user error!
Mine is weighing in at about 1480grams. I am now running the mid motor and have nothing bad to say about it. the turn in that I get is unreal.
As I am still learning the ins and outs of setup and gearing I couldn't tell you where to go or what to do. sorry for my noobish behaviour. But we all have to start some where don't we!
As soon as my post count is up I will start posting pictures.
Out the box setup was how I first used it with different shocks and springs. Still schuie parts and springs. I was three hundreds of a second behind my cxl which I have been toying with for the past few months.
So on a side note I am seriously impressed with the Mi5. Managed 3rd in the c final at chatham maritime raceway uk last night and had no top end on the straight. It kind of died coming half way up the straight but ment I didn't have to break for the turn!!!
Will report back with more news soon.
Captain out
Captain out
#707
Captain out
Captain out
Didn't know we had another mi5 driver there last night! Glad it's working out for you! I love my mi5 and getting it going a lot quicker than the mi4cxl too - come and have a chat next week and we can compare notes!
All the best
Paul
#708
I am not there as much as ide like to be. And highly doubt I will be there next week. Truly gutted to be honest. If only I worked 9-5it would be ok! we sat back to back in the pits I think we chatted a few times. you helped with my cxl?? I am the ginger 1 that asks too many questions!
#709
In the manual the setup sheet for Cotswold has the droop set as 4mm Rear, 4.5mm front but the box for On 10mm Block is not ticked... so is this droop done over ride height?
So the rear ride height is 6mm with droop as 4mm - do I set the ride height to 6mm and then with the wheels and shocks etc still on I put the car at 10mm on the ride height gauge and do the droop screws until the wheels just leave the setup board on each side?
#710
Put the car flat on your setup board without wheels and use a ride height gauge to set 4mm and 4.5mm on the wishbone under the outer hinge pin.
#711
#713
#714
Would be really cool if you could help me sort my gearing. The car is really nice through the infield but gutless on the straight. I started as a base by mirroring my gearing from my cxl. but I think because the speedos are different the final gear doesn't have the same effect as it does on the cxl. I know there are lots of different factors as well like boost, timing. And how I need a smaller spur so I can fit a large pinion on there. With an 85tooth spur the max I can run is a 29 and its a tight fit and it makes a horrid noise. I thought it was going to strip the spur of the line in the final! Do you recommend dropping down a tooth so I don't run on the limit??? And so I can actually feel some backlash between the spur and the pinion?? I have the feeling I am only looking for about 2-3 more teeth on my pinion to find the desired top speed I think I need. What sort of shock and spring combo did you run In the end for the final?? The long and short of it is I would like to find a nice middle ground where I am not running on either extreme! if you understand what I am saying. Maybe this would all be easier if I just let you drive my car!
Yours sincerely
Captain
Yours sincerely
Captain
#716
Yours sincerely
Captain
Yours sincerely
Captain
Also have a look at the timing on the motor.
I'm currently running yokomo pink and blue springs with 450wt oil all round and the car handles great. Need a bit more initial steering so will try blues all round next week.
Been using Hofer's lrp setup with a few tweaks - try it out.
#717
Does the Mi5's rear gear differential (PN U4333) fit in the front of the car too? Or does only the Spec-R gear diff PN G868 fit in the front?
Wondering because I am considering a gear differential for the front, in lieu of the kit spool.
Bill S
Bill S
#718
Only the spec r gear diff fits in the front.
Captain
Captain
#719
Thank you. Whew, I'm really glad I asked because I would surely have bought the wrong one!
Bill S.
Bill S.
#720
