Team Durango DETC410
#1396
#1397
What is the part number of tamiya that will work on this car for steering locks ?
#1398
Set up for vta please. What to buy. Before hand.
#1399
What shock springs work for this car
#1400
VTA set-up
Build it to stock set-up with soft springs in front, medium in rear and just a front sway-bar. Lean the shocks in front and rear, run 40-50 weight shock oil and minimum rebound. Try the Elliot Harper set-up for low bite carpet. I suggest you get some spare C hubs and spur gears. DP
#1402
Tower hobbies has springs for this car.
#1403
I have all 4 springs, both sway bars front and rear , all the turnbuckles all 7 sealed, and ball connector parts tree still sealed, 19usd shipped
#1404
Yokomo pink front
Yokomo blue rear
37.5 wgt oil
Yokomo blue rear
37.5 wgt oil
#1406
Parnelli I took your suggestion and removed rear swaybar and moved shocks all the way in. What a huge difference on our little slick cement track. Outside temp got up to 75deg today so pavement got warm, combined with the changes it was like a diff car. Ordered the softer springs should get even better. Thanks for the advice.
