Team Durango DETC410 >
Like Tree4Likes
Old 04-26-2015, 04:21 PM
  #1081
tbrymer's Avatar
Originally Posted by rcgod
Measure the length of the stock belts and try to cross reference them with low friction belts for xray or tamiya or one of the more popular cars.
Yeah, I haven't done an actual measurement, but noted the # of teeth and tried to look for something using that, but didn't work out. I was hoping someone has done this. I know some guys cut off every other tooth, at least in stock classes.
tbrymer is offline
Old 04-26-2015, 04:46 PM
  #1082
rcgod's Avatar
Trader Rating: 33 (100%+)
From what I've read the front is same length as trf417 and top. I'm still looking for a rear.
rcgod is offline
Old 04-26-2015, 05:19 PM
  #1083
rcgod's Avatar
Front low friction belts 173t:
Top PO-PDT012
3racing SAKD116
TAMIYA BT-003
Rear low friction belt 62t:
Robitronic RA1961
There might be others but those are what I found based on 173t belt length 519mm, and 62t 186mm.
rcgod is offline
Old 05-09-2015, 07:23 AM
  #1084
any news on those new parts coming arms etc etc
pete68 is offline
Old 05-09-2015, 04:55 PM
  #1085
rcjunky1's Avatar
Nothing public yet. I just got 3 of these in the mail, should be running it in 2 weeks
rcjunky1 is offline
Old 05-10-2015, 05:01 PM
  #1086
tbrymer's Avatar
Top PO-PDT012
3racing SAKD116
TAMIYA BT-003
Robitronic RA1961
Thanks for this info!!!
tbrymer is offline
Old 05-13-2015, 01:20 PM
  #1087
olhipster1's Avatar
Trader Rating: 102 (100%+)
Default just posted
in case anyone is interested.
http://www.rctech.net/forum/r-c-item...tc410-new.html
olhipster1 is offline
Old 05-18-2015, 06:35 AM
  #1088
Anyone having problems with the glueing of the lay shaft pulleys? Mine keeps on coming loose, so every weekend I have to change them. Belt gets between bracket and pulley... I used brake cleaner and some sand paper before glueing, nothing seems to help...
And for th people in Europe, where do you get your parts? In Belgium it seems very hard to get parts, UK is much better but with the exchange rates...
viper977 is offline
Old 05-18-2015, 07:38 AM
  #1089
tbrymer's Avatar
Yep, I've had this problem a couple of times.
tbrymer is offline
Old 05-22-2015, 12:48 PM
  #1090
Laker67's Avatar
Trader Rating: 69 (100%+)
I just built one of these new for my 17.5 car and then just picked one up used that I want to run as my USGT. I bought Serpent Gears for my 17.5 car, since they were available on amain but they didn't fit the way I expected and I had to grind a little bit off of them. Where are you guys buying gears from? I know Spec-R makes them and you can get Panaracer gears, but what online store in the states are you guys getting these from? I would hate to wait weeks to get gears from another country if possible.
Laker67 is offline
Old 05-22-2015, 01:03 PM
  #1091
b20btec's Avatar
Trader Rating: 11 (100%+)
In stock at reflexracing.net
b20btec is offline
Old 05-22-2015, 01:06 PM
  #1092
olhipster1's Avatar
A lot of places try Reflex Racing,
Stormer, Amazon, but first ask your LHS
Old 05-22-2015, 01:08 PM
  #1093
Crowbo74's Avatar
Trader Rating: 111 (100%+)
Default Tqrcracing.com
Tqrcracing has some of the panaracer gears in stock. Common gears are sold out like the 96 and 100 but 95 and 101 tooth are in stock.
Crowbo74 is offline
Old 05-23-2015, 09:58 PM
  #1094
BLbound's Avatar
Trader Rating: 27 (100%+)
I'm thinking about picking 1 of these up...what's the pros & cons you guys have found out? I used to run TC back in its heyday...last car I had was an X-ray T2. Looks like spare parts are reasonable on tower...it also looks like the best bang for your buck...lmk what you guys think please!
BLbound is offline
Old 05-23-2015, 11:19 PM
  #1095
rcjunky1's Avatar
I ran mine for the first time yesterday (well, Friday) and was very impressed. It was pretty durable as I hit a lot of stuff hard, and handled really good. Driver skill was the biggest limitation for sure. It was my first time running a sedan but have run a lot of off road and know how to drive, but them corner dots send your car flying when you get a little bit too close :P I slammed a board hard while leading the B and made the motor shift forward a lot and nothing broke. My car has the flex control mount and steel outdrives but is otherwise stock as far as I know
rcjunky1 is offline
