Who charging 20+ amps or more now??
#437
There's s large discrepancy between different chargers then if a brand new SMC pack reads about 2.5 ohms on a PL and an older pack of any kind reads 1.8 to 3.0 ohms for the pack (big range isn't it?). You mean 6 milliohms? .6 milliohms would be 0.06 ohms right?
So a reading of .6 per cell for a 2s would be 1.2ohms? I don't know if you can spend enough money to get a pack with true IR that low.
Teperature when taking the reading has a big influence as well.
I guess just go by what your charger reads and monitor the packs heath based on those reading right or wrong.
#440
Damn, can't get over some of the crazy charge rates I'm reading here.
My Orion 6500's came with a note, do not charge over 5 amps so that's what I'm gonna do, charge at 5 amps...
I'm not lacking speed at all... My charger wants to charge at 1C but I turn it down to 5 amps. If I'm in a rush and I'm feeling all cwaaazzzyy I'll charge at 6.5 lol...
#441
Their covering their butts in case of a lipo fire.
Lipo technology from 8 or so years ago could only handle 1c charge rates. Now just about every lipo can handle 2c or higher safely and the better packs can take 3c or more... but they are also covering their butts and saying 2c max.
There has been discussion that charging at less than 1c is not good for the pack. Not sure about that, who knows.
You are more than safe charging at 2c and you should go by what the pack says... not the charger. They obviously are not aware of every pack that may be charged by their charger, their attorneys said to put a note in there saying not to charge over 5a. What if you were charging a 10,000 pack for a plane? Still 5a max?
#442
My Orion Advantage Touch Pro Charger can charge at 12A, f*ck it I'm gonna start charging at 12A...
#444
In the Description it says "Up to 5C"
Here is my point, are they covering their @sses for indemnity reasons or can I ignore this. They started manufacturing these in 2009, so perhaps the technology is a bit legacy...
#445
Interestingly, on their new 8000mah packs they don't have a max charge rate, so I'm guessing it's a free for all.
http://www.teamorion.com/carbon-pro-...ubes-en-2.html
#446
Assuming the 8000 packs are 5c, that's a 40a charge rate and not many chargers get that high.
The ones that do certainly know what a pack can take and won't give more than that. Probably why they don't even bother to list a max charge rate.
Most of the chargers over the last decade will not charge higher than the pack wants to take also so you can just about set it to max and let it go.
You may set it to 12a on an old cheap pack and a good charger may charge at 6.85a because it can sense that's all the pack wants to take.
#447
#448
Team EAM
Just one important thing to remember regardless of charge rate is make sure you use the balance option on the charger! Ive yet to see any lipo go up or have problems on a balance charger when the balancer was being used. Most "good" chargers have safety features built in that will terminate the charge if there is an issue.
EA
EA
#450
EA
EA
Only one reason not to balance charge, speed but its not that much faster and not worth it.
