ta05 ifs gearing question
Hi every one!
I picked up a used TA05 IFS-R and wanted to know with a 21.5t what should the gearing be? I thought first it might have been something in the causing drag in the car but took it all a part inspected cleaned and oiled every thing its all moving freely the gear mesh is good too so i'm thinking its a gearing problem
right now its 80/56 and its hitting 190 degrees in less then 5 minutes on 2s lipo
setup
LRP Vector X12 21.5t, Tekin RS & 2s 7.4v lipo no timming in motor or ESC
setup
Super Moderator
It depends a bit on what you're trying to do with it, are you racing on a track, or just bashing with it? That being said, 80/56 sounds like WAAAYYY too tall a gear ratio, even for playing around. I'd start with something more like a 4.12 FDR(which you can get with an 88T spur & a 48T pinion, assuming you're using 64 pitch gears), it may not be the perfect FDR, but that should be a reasonable starting point(for either racing or playing), should run much cooler & longer that way....
