Reciever Battery Pack
Can someone recommend a good receiver batter pack for my DM1 1/7 ? Right now I'm using the 4 AA stock battery setup but am upgrading to Savox digital servos and I need a more stable battery system that can also provide more current. The factory weight of 4 AA's is 97 grams, I'd like it to be lower than that. Also, do I have to get a voltage regulator or no??
Thanks,
Greg
Thanks,
Greg
Thanks,
Greg
Thanks,
Greg
http://www.amainhobbies.com/product_...ck-66V-1300mAh
A good quality 1600 to 1800 nimh receiver pack will give you more power than the AA but probably weigh more.
To be lighter you will need to go Lipo or Life
for LIPO you will need high voltage servos and receiver or add a voltage regulator, the regulator will add some weight and extra wiring.... just adding more stuff to go wrong in my opinion
For LIFE you shouldnt need a regulator and will be lighter...so thats sounds like what you are looking for.
So you can pick what you want to deal with....each option has its pros and cons.
I have stuck with using a good quality NIMH pack after seeing connection and regulator issues on fellow racers cars running lipos. A few racers tried LIFE when they were brand new a few years back, they worked well but the packs didnt last a whole season. The packs started to fade in longer mains over 20 minutes, but I hear the life packs have improved lately.
Ok cool, LiFe sounds like the way to go. The pack that esckalayd posted a link to is 85mm in length and the battery holder on the DM1 can hold about a 60mm pack, do they make a LiFe pack that will fit into my battery holder thing or is there another option such as a different battery holder?
Thanks for the quick and detailed responses!
EDIT: Will this one work fine? http://www.amainhobbies.com/product_...-Balancer-Plug
As far as brands go, is there a prefered brand?
Also, I'm seeing run times of about an hour with these packs..... My AA's have provided over 3 hours so far of run time.... Seems kinda backwards to me.
that should not be a problem i run savox in my GT and have run practice last chance qualifier and main without recharging but i do normally like to put it on between rounds if possible just make sure all your linkages and radio are set up right a savox will 3 amps or more if held against a physical end point
Do you have a charger capable of charging LiFe/LiPo?
Any non or basic computer charger do moostly NiMh and NiCad and you can not charge LiPo/LiFe with it. If you do not have such a charger it is wise to get a simple NiMh Humpack.
I do not have a charger, but from what I see they're only about $100.
http://www.cheapbatterypacks.com/pro...-1500-23A.aspx
ive been buying loose 2/3 a from here and soldering them up my self.......so far so good...and cheap
http://www.batteriesplus.com/product...6/PowerEx.aspx I have used these to make 5 cell packs for Team Pursuit and they will weld, solder, (lead i supplied) and shrink wrap for you (at least my guy did)
