Protofab Camaro bodies
Does anyone make a body of the Protofab Camaro race cars such as this. http://www.historictransamimsa.com/M.../protofab.html
There's the Customworks IROC Camaro body, but you would need to modify a buggy or an old wide 1/10th pan car to go under it, it's quite a bit bigger than a touring car shell at 230mm wide with 280mm wheelbase.
I see RAE has one too, would this or the other ones fit a converted stadium truck and/or an old RC10 pan car or the new Turnigy pan car.
Thanks in advance! http://www.randersonengineering.com/...0page.htm#oval
Both bodies were designed for old wide pan cars and converted buggies and will fit either.
The Turnigy pan car is a modern touring car size chassis, these bodies are way too big for them.
Thanks, which chassis would you recommend. Personally, I think an old RC10L might work but then again maybe not
Yeah an old 10L would be perfect, light weight and rear wheel drive means it would be a handful but handle like the real thing.
Thanks alot for that, i will definitely be looking on Ebay for an RC10L and an RAE (or hopefully Protoform if they make them) Camaro body
