TLR TEN-SCTE 2.0 Kit Thread
#7921
I just ordered this truck and now I need electronics. What do I get? Thanks
#7923
rx8 180 amp for the high end choice,hobbywing 150 amp for the budget,wouldnt even consider much else in a sc
#7925
You seem to be rather stuck on the amount of travel or degrees that the truck itself steers. I can tell you that if you want more steering travel, you can use the aluminum 15 degree caster blocks. I have never had a problem steering with my truck. As long as you ensure your right and left steering link are the same length as they should be, you should be fine. I dont dremel anything in my steering at all and had no issues turning under anyone this last weekend.
brax..if your way off on left steering and havnt grinded anything,take your front brace off and get good look at the right side steering ball,its hitting the diff case and stopping your full turn,grind it out a tad
#7926
If my kit ever gets delivered I'll join the club .. so far I've got the mamba max pro sct 2400kv spektrum high tourqe servo and since I love my badlands on my baja 5b I had to get a set for my sct
Also do the rpm a arms for the 1.0 version fit our 2.0 kits?
#7927
Thanks for the help guys, cant wait to get building it!
#7928
You do not need RPM arms, stock one are really beefy and hard to break. Since 1 year and half I have not broken a single part on this truck, I only changed part because they became sloppy.
#7929
#7930
The only thing I have broke was the left front spindle carrier, and that was because someone else does not pay attention to the announcer when he says over the PA to "WATCH THE END OF THE STRAIGHT" I was setting against the wall and some other guy came full blast down the straight well over 100 feet and used my truck to stop before he turned the corner. He blasted me head on right on the left front wheel and I was surprised nothing else was broken. And I am still learning to race this thing and put it to a stress test all the time.
#7931
in the updated parts for the 2.0 was the 15 degree caster blocks part of the upgrade but in plastic rather than the alum aftermarket ones? I would like to try them but if they are becoming a TLR part I'll just wait.
#7932
Wanted to send a huge shout out to Casper, hacker and integra for helping me get through the build of my first 4x4 sc kit. All your tips helped out a lot. Much appreciated!!
#7933
#7935
