TLR TEN-SCTE 2.0 Kit Thread
#7231
#7232
Never ran a tenshock but the hw 4k is so fast and smooth and runs so cool it is darn near perfect. Also I only race so never ran a 3s but from what ive seen out of my buddies slash 4x4 on 3s that the 4k would be just too stupid fast with a 3s. Might start running into heat issues with that set up as well.
#7233
Teamfasteddy (from Fast Eddy Bearings) has a whole line of videos up on youtube walking you through the build incase you run into any issues or get confused. I had it playing while I was building just incase I ran into any questions. Make sure you get the bearings all the way on. They seem to fit really tight. Enjoy the build, I love my truck. Had a couple people Tuesday night come up to me and ask what motor is in mine (Hobbywing 4000kv) and they just couldn't believe the power it had even on no timing. Made a few more believes in Hobbywing that night. I'm geared 15/40 right now and the highest temp so far is 170 on the motor and 100 on my RX8. Just ordered a 39t MIP spur. Trying to smooth out the power some as it's just a monster.
#7234
Thanks again! Ordered the HW combo today... can't wait to test her out. Will be picking up the servo, tires, and paint tomorrow.
#7235
You'll love it. The 39t MIP spur helped smooth the bottom end out some. Topping out at 170 degrees after a full pack on a 15t. Stepping down to a 14t to knock down the temps just a little as 170 is just a tad bit high for my liking.
#7236
#7237
#7240
I went thru the trouble of bending them to match mine. I didn't know if them being a little wider would hurt anything like floating side to side but it's all good now. looks like i'll be running the new setup except for the front aluminum 15deg hubs.
#7241
#7242
Going to post this here too: Has anyone else experienced bad suspension binding in the rear end? Truck is a 2.0. I'm getting absolutely no rebound. Just rebuilt the shocks. Same as before on old oil. Bent hinge pins?
#7244
Arms are pretty free. No binding and go to full droop no problem. What shock setup are you guys running? Maybe I'll start playing with the bypass...
