TLR TEN-SCTE 2.0 Kit Thread
#7081
I use the novak 4.5t 550 can now but on some of the layouts my track will have I'm always looking for more motor. I still do very good with the 2pole 550 motor but sometimes when I'm battling with a 4pole motor they have a little more yank and can get past me.
#7082
15 deg alum spindle carrier
Broke right side. Cant find one in stock. Any word on when these with be available?
#7084
#7085
What are your tire recomendations for Bashing and having fun on race tracks ?
#7087
I finally got to race this past weekend and the truck really done a lot better . At least I could take corners with out spinning out every time. But I have a cpl questions.
1. are there heavy duty ball ends I can get to replace the stock steering ends ? there's soooo much slop in my tires I cant even set my camber
2. I put the RPM front bumper on my truck and after every race I had to re tighten the 4 screws that go thru the bottom into the diff . My question is do I need to replace the front diff ? Or is there something I'm missing ?
#7088
2) Before replacing the diff case get longer 8-32 flat head screws and see if that solves your problem. I'm using longer screws and I've had an RPM bumper on for so long that all the ribs on the bottom have worn away months ago. The screws never come loose except when I take it apart for maintenance.
#7089
If you are bashing frequently, then you might like to try the Proline Trenchers which have big lugs and seem to last a long long time (still on my first set). If you're bashing out in grass fields and dirt, then the Proline Badlands will give you good traction, but might round off quickly on tarmac.
#7090
What is the part no for the black fr a d silver r springs used n the latest dunford setup thanks
#7091
General advice - as Casper said...
#7092
Hey Guys,
I'm having a weird problem with my truck. After about 5 minutes of the truck running great it cuts out and only has about a quarter throttle speed. I check it out and the low voltage red light blinks on the esc. I turn it off, try again and the same thing happens (runs for a while then cuts out). Temps are good on the motor and esc. Things I've tried: 1. Replaced motor and esc. 2. Changed receiver. 3. Tried all 5 of my 2 cell batteries and checked the voltage of batteries (still charged).
The only thing I haven't replaced electronically is the Servo. And the truck rolss freely with no binding. Any ideas?
I'm running a Reventon Pro 1.1 with 4.5t TrackStar motor. 4pl transmitter with futaba 3 ch receiver. I was running a Novak Ballistic 4.5t with Havok Esc. Thanks.
#7093
Hey Guys,
Normally I would say it's the low voltage setting on the esc, but you tried a different esc and it doesn't make sense that it would be the transmitter.You could check all the settings on it. You could try someone else's batteries. May be there's an issue with your charger.
#7094
I also used the old 4mm bullet connectors from the esc to the battery. They are the kind that spin around. i wonder if maybe one of those is bad? I'll change them out tomorrow.
The batteries I have work fine in my Slash so I don't think it's a battery problem.
