TLR TEN-SCTE 2.0 Kit Thread
#6706
What do you guys think of the aftermarket chassis kits for the SCTE 2.0? I bent mine and I'm looking for a replacement now. Kingheadz, BCE, or stick with the original TLR chassis? I broke the rear chassis brace plastic rod end at the same time I bent the chassis. I'm more a basher than a racer, so whatever I get, I just want to be sure I'm getting the strongest set-up. I also want to order MIP's front and rear chassis braces at the same time. Thoughts and advice welcomed!
#6707
For quality you can not go wrong with either the BCE or the Kingheadz. I personally run the BCE and love it.
#6708
JoeC, with what braces? the original TLR's? had any issues?
#6709
#6710
Thanks guys. I guess all of these chassis designs are probably prone to bending. It's the chassis brace that needs to be stronger. I saw a video on youtube of a guy who was running some STRC chassis braces, but I don't know what the part number for them is. They look stronger than anyone else's that I have seen. I've even thought about machining my own braces, but if it's quicker and cheaper to buy something, I'd rather do that.
#6712
The problem with a super stiff chassis brace is that it actually causes u to lose rear tractiin the stiffer that u make them. I have the bce v2 chassis and switched to the 1.0 plastic rear brace. Seemed to gain a little more rear traction that way and have not noticed any negative effects since doing the mod.
#6714
Interesting about the chassis flex aiding in rear traction. That's where the words flex tuned come from, I suppose. I mainly am a basher, but I thought if I could find a few local tracks, maybe I'd join in the fun, just to give it a try. Who knows, I might like it.
So what do you guys think of the MIP chassis braces?
#6715
Track driving is where its at. I used to bash only as well. Get a transponder to hear your lap times and you will be hooked and racing in no time!
Edit- I am running the MIP rigid chassis braces and don't notice any loss of traction, gone are the days of breaking plastic ends...
#6719
#6720
TLRacing
