TLR TEN-SCTE 2.0 Kit Thread
#6662
I installed the new 15 deg +2mm front castor blocks and +0.5mm rear hexes in my version 1.0 for this past Sunday's outdoor season opener at Barnstormers in NY. The new handling was quite impressive. This is a large 1/8th scale sized medium grip track, which gets fairly bumpy by the end of the day. I was able to TQ 4wd SC with my truck. !
#6663
Can somebody tell me what are sizes of sway bars come in this .losb2222. Thank you.
#6664
I have a question about bump steer. A lot of the setup sheets I see have a 2mm washer added for bump steer. Would I be correct to assume that the 2mm washer adds bump steer (which I believe adds toe out at full compression)? When using bump steer I have also noticed that most setup sheets have +1 or +2 degrees of toe in. Can someone please elaborate more on this as it pertains to how it affects the handling of the truck on the track.
Question # 2: When you set toe in or out I have always set it at ride height. Is this the correct way to do it? Thanks.
#6665
I have been running the mip braces since they came out both indoors and out. I did not notice a loss in traction when running on indoor clay tracks I see no down side to running the mip braces with the stock chassis.However I did run them with a BCE chassis and did not like the way it drove.
What Chassis? H1 or V2 Pro?
im in a stage where i have both V2Pro and TLR's chasi laying around and both the MIP Pro4-Mance SCTE 2.0 Rigid Chassis Brace Kit (MIP13249) and Team Losi Racing Front/Back Torque Rod Set.
What do you suggest? to use MIP's? TLR's? to mix them? (using one as back and the other as front)
#6666
Do you guys have or had any problem with the steering link rubbing the top of the front diff house? happens both with Stock Steering setup and the integy unit on both TLR and BCE chassis... everything is brand new..
#6668
What hex pins for the wheels will work with out having to buy new hexes? Thanks
#6669
Anyone still having an issue with Nose Dive off jumps? I've tried a new motor, still happens. New softer rear springs, no change. This thing is almost un driveable. I can't find any evidence of drive train binding either. Checked gear mesh too, and that looks fine. I'm not a pro, but not a noobie either. Any help would be appreciated. SCTE 2.0 Tekin 4300HD RX8 Gen 2.
#6670
#6671
#6672
Tech Prophet
#6673
Everything everyone's said is true about the nose dive issue. Realistically, all I do is throttle up in the air and that levels out the truck. The nose down jumping is helpful for downsiding jumps though. Drag brake definitely makes it worse. But applying more throttle in the air and backing off just before landing has been working for me since day one. My 22-4 jumps the same way, so I use the same technique.
#6674
#6675
R/C Tech Elite Member
I have same Issue, running this truck a long time. Some days better than others, Check gear mesh, never run Drag brake. I started running softer shock oils and will try going back because the nosedive is back and when I go for big jumps the Hekno guys fly flat over. Mine dumps the nose it's the only problem I need to solve on this truck. I have to full throttle in the air. if I let off It lands nose first..... sigh.... i'm not novice
