TLR TEN-SCTE 2.0 Kit Thread
#6076
Hi,
I'm new to RCTECH and just in the progress of switching from a Durango DESC410v2 to the TLR SCTE 2.0.
(The desc410 is fast but I had some issues with the durability and quality of parts and I want a SC that is easy in maintenance)
I've been attending some indoor races so far with my rango and now the next 4 races with the TLR will also be on carpet... I'm looking forward to build and setup this badboy
While I had been running a 5.5turn VST2 550 2 pole Team Orion on our medium-small outdoor track, I did us a 4600kv 540 4 pole VST2 Orion for indoor carpet racing so far... seemed to have enough speed and power.
But when I look at the (US) Nats or EOS and other large races, the pro drivers seem to race 2 pole 550 cans more often? Is there a reason for that?
Thanks,
Dave
Thanks,
Dave
#6077
Quick question,
When using shocks to limit droop, is there anything special I need to do to the shocks? (other than adding an extra couple turns to the eyelet?)
Thx
Thx
#6078
Tech Prophet
Rear end we have been running 3 deg antisquat (1's up in the front) and 3 deg or toe in (0's) for the rear pivots.
Nope. Just make sure the set screws in the arms don't touch anything.
#6079
Nope he is running the MIP spur.
Both setups I have posted on my site have 0 inserts all around in teh front.
#6080
#6081
Tech Prophet
What is the part # for the Torque Rod ends ?
http://www.amainhobbies.com/product_...Torque-Rod-Set
Just the plastic pieces work though. The balls are not the write size but this gives you more rod ends for a little less money
Make sure you screw the set screw all the way into the plastic piece FIRST and then what ever is left thread into the alum rod. they last much longer this way.
#6082
Thank you !
#6084
Tech Prophet
So I recommend a Tekin SC4X 4.5T motor.
http://www.teamtekin.com/sc4x.html
There is a little bit of a weight penalty to going 550 as well. Just putting it all out there.
#6086
Tech Prophet
#6087
Lower number means faster motor. You would be looking at getting ahold of a 4.5T. 2pole will have a little more top end and resond a little better to timing advance in the ESC then 4 pole so on a large open track they can have better top end but you will be giving up a little on the bottom to a 4 pole. Just giving you the pro's and cons.
#6088
Finally got my SCTEN 2.0 and have finished building the front section. For the diff screws M2.6 x 10 can anybody recommend a good replacement set? I nearly stripped one of the screws even so I was really careful... Thanks!
#6089
I just got an interessting answer from a former Durango pro driver - he said, since only a few of the 1/10 racing ESC's that they have to use do support 4 pol, they just run 550 2 poles (EOS races etc.)
HPI makes some better 2.6's Kinda surprised we haven't gotten better hardware for the diffs yet. o well
