TLR TEN-SCTE 2.0 Kit Thread
#6046
I have the 2.0 with a tekin 4300 and RX8 gen2 speed controller. This setup was bought new 2 weeks ago. I am running a high voltage servo. I have a glitch buster. My problem is this thing will stop running I will still have servo but no throttle. My motor and speed controller is running cool. Motor 135 deg. speed controller less than a 100 deg. I am running a deans plug to connect battery. Battery is a SMC 6500. Sometimes this thing will only run 5 minuets and sometimes it will run for a 8 min race. Battery is sometimes still at 65% when it does this. Please help
#6048
#6049
http://www.casper-rc.com/images/TEN_..._13_reduce.pdf
What is THE setup that everyone is using as a baseline? Also, anything not included in the kit that I should order? Different springs, pistons, necessary upgrades, etc?
#6053
http://www.losipartshouse.com/servle...ies/Categories
The springs and pistons are on this page.
I love Losi parts house, those guys are on the ball with shipping and they have great prices.
#6056
this tower shock have 2 hole as i mention it before...
lower hole for original shock (12mm) and higher hole wich is 9mm taller than original is for big bore 16mm shock. and seat perfectly...
you may cek to SNR graphite...
thx
thx
#6057
It takes a VERY hard smack, but I have seen it more than a dozen times, under the same circumstances. There was even a thread about this several months ago, and someone explained why it happened (not sure what site, though). Maybe Randy Pike can chime in for an explanation. In fact, we saw this four times yesterday alone! (It was a very tricky jump we had to adapt to.) All of our ESCs are relatively new, or new, so something is certainly going on!
There has to be a benchmark with how much of a hit it should be able to take and keep on ticking.Perhaps the jump you speak of is over that very benchmark?.
