TLR TEN-SCTE 2.0 Kit Thread >
Like Tree10Likes
Old 12-03-2013, 04:48 PM
  #5746
Redwings's Avatar
Default Motor space
Ok, I just got the SCTE 2.0 and noticed the motor mount with the motor only moves so far. I noticed that motor hits the plastic bumpers that run along the side of the chassie. I have already shaved the bumper down a bit to get the proper pinion / spur alignment. Is this a common problem, what should i do?
Paul
Redwings is offline
Old 12-03-2013, 06:46 PM
  #5747
TCCustoms's Avatar
Paul
Sounds like the common mistake and the side plates are on backwards or your motor has extra mass and your going to have to grind down but i have the Hobbywing 4000kv motor and the fins add pry 1/4 of a inch and i didnt have to trim much so if you have that kinda motor that could be the issue but i bet its the side plates are on backwards as i myself even did that and i knew how to do it as i read the manual and the assembly instructions Ryan posted....
"Side-Guards (F-1) – When installing the side-guards onto the chassis, at first glance, they look the same, however they are different. One side holds the battery in place and one side allows room for the motor. If you look along the inner edge of the guards, you will notice one has a high spot and the other is low the entire way. The one with the high spot is for holding the battery and is the left guard and the other lower one is the right guard."
TCCustoms is offline
Old 12-03-2013, 09:40 PM
  #5748
Thanks for the servo help. I'll take the front end apart and retighten the servo saver (back off two turns) and use lock tight.
Cheers
braderb is offline
Old 12-03-2013, 09:41 PM
  #5749
Cheers
braderb is offline
Old 12-04-2013, 03:47 AM
  #5750
Cheers
Mines locked all the way down for maximum steering response. It's taken some hard hits and the servo still works fine.
87MagnumII is offline
Old 12-04-2013, 04:47 AM
  #5751
Redwings's Avatar
Paul
Thank you for the adive tc Customs. Lets Go blue
Redwings is offline
Old 12-04-2013, 11:41 AM
  #5752
Suspended
Trader Rating: 132 (100%+)
Originally Posted by Panda-PR
Parma rally body on my 2.0!! Just have to raise the body post and remove the rear bumper.
I would like to see some more pics of this, and video.
Also, maybe post it over in the Losi Rally X thread. I know it is not quite the same, but this is a nice example and wi give some life to that thread
badaml is offline
Old 12-04-2013, 05:16 PM
  #5753
The latest Dunford setup (7/1/13), what inserts do I need to run on the rear? I see 0 inserts for the front inside and front outside.
potatobed409 is offline
Old 12-04-2013, 08:38 PM
  #5754
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Can someone link up the spring rates for this truck please. Thanks.
Never mind found them... Duh
UN4RACING is offline
Old 12-04-2013, 08:53 PM
  #5755
rcgod's Avatar
Trader Rating: 33 (100%+)
1 up in front and 0 in rear.
rcgod is offline
Old 12-05-2013, 03:23 AM
  #5756
Thanks. I figured it was kit setup since it wasn't posted, just wanted to be sure.
Old 12-05-2013, 03:30 AM
  #5757
sickpuppy1's Avatar
Trader Rating: 32 (100%+)
putting yours together, or is it done?
sickpuppy1 is offline
Old 12-05-2013, 04:41 PM
  #5758
UN4RACING's Avatar
Its hit the track for practice and on pace. Going racing this weekend.
Old 12-05-2013, 05:47 PM
  #5759
sickpuppy1's Avatar
Too bad I'm working.... Like to see that
Old 12-05-2013, 06:30 PM
  #5760
UN4RACING's Avatar
Matt and I have been dueling for the past to Tuesdays. Hes got me on fastest lap by a thousandths. So I think its going to be a pretty good season. Top 5/7 drivers are on the same lap. So looks like its going to be like the worlds every Saturday.....
