TLR TEN-SCTE 2.0 Kit Thread
#4636
Why do people put heat shrink tubing on the solder posts? They are intended to help cool the ESC
#4637
I'm pretty sure if you thought about it you would figure it out.. That being said, now thinking about the cooling aspect it does make since. But I'll leave mine on to protect it from possible arching er wires touching it etc...
#4638
I've been running a 4600pro4 in my 2.0 since I got it w/great results but w/the outdoor season being so damn hot this year I decided to drop in a Reedy 4.5 550 to save my lipo's and keep temps down. We were on a big track w/big air so i added 80 timing on my rx8 and geared up to a 15/41 so I could clear the huge triple. I have been very impressed w/a 4.5t in this truck for outdoor, Super smooth, cool temps, plenty of nut.
#4642
Im racing with them on, they look realistic
#4644
Ryans New Setup
For the guys running Ryans new setup a couple questions:
1) rear hexes spaced out 0.5mm is that for each side and how are you spacing them out?
2) what are the witness marks on the front arms and steering links dremel accordingly?
3) any starting point for the droop measurements?
#4645
0 insersts new set up
And for those, yes the kit was built with -0- inserts so no need to tear down the whole front end like i did
#4648
2) Witness marks will be where the wheel is rubbing the arm and steering link just grinf those areas down until you cannot see them. Also, if you haven't put the 2mm under the steering link on the outside, the squares from the diff make a nice 2mm spacer.
3)We do not use droop screw for this setup. You want to take the front shock ends go up until they stop and unsrew them 2 full turns. The rear do the same but only unscrew 1 turn.
