TLR TEN-SCTE 2.0 Kit Thread
#1682
Transponder goes on the side of the servo next to the receiver. ESC goes on the chassis to keep CG low. A lot of us cut the ESC try off the 1.0 and mounted to the chassis. They added some extra material on the chassis where the ESC goes to make sure there is enough surface to stick the ESC on. I would not Velcro the ESC to the car. I would use a good double side tape. The ESC should not move get close to the center brace.
Yes you need a bit of wire for this truck but a small price to pay for improved weight balance.
Again on the 1.0 a lot of use did not run boots. You can always by them as they are still available if you feel you need them.
bit
as far as the velcro..i have always used velcro to hold my rx8 in place..at one time tekin reccomended it ..it allows the esc to move without absorbing too much shock..i like the idea of cutting the old mount off and using it..i had thought about that also....by the way i use an awsome velcro that holds so well i have to use a screw driver to pry it loose when needed..but it allows it to move a bit to help with shock
#1683
Now that the SCTE 2.0 is out, would it be stupid to buy the SCTE 1.0?
I only have bashers, but would like to start racing. I have never driven on a track. Because of parts availability and help at the track, the SCTE is the best choice for me; but which one?
I'm convinced that all the hop-ups are an amazing value, but are they going to help me be more competitive; or achieve "decent driver status" any faster?
If the answer is, yes, I'll get the 2.0. If the answer is, no... then it'd be a toss up.
I'm asking sincerely.
I would love to have the latest and the greatest, and a KIT, but double the $$. hmmmm
Not bad for the first time out with the truck...
#1684
Just finished putting mine together last night. Didn't strip out a single screw in the kit. The bottom of the stocks was a PITA to install. I think a 12mm 6 point socket was able to help me get them on without marring up the cap. I'm using the hobbywing SCT 4000kv combo for the next month or so. Along with an Airtronics 94358 Servo. I'm using this servo because I have it laying around and it's a good servo. I'm planning on using the RX8 along with the Pro4HD when it comes out.
Now I just have to paint the body and mount the tires. Think I'll know that out today after I figure out what pain scheme I want to do.
#1686
Tech Prophet
yeah i mounted my receiver and transponder to the side of the servo..i just didnt like having the bundle of wires exposed..looks sloppy...
bit
bit
#1687
TQ and a win for the first time out yesterday. Truck was dialed with the Dunford/Casper setup. The biggest reason I will not change to another manufacturer is the support everyone gets from the team. The truck went together perfect ( ya ok maybe one diff screw and iv'e been doing this for over 30 years so I guess that was just a rookie mistake LOL)
I didn't need a longer sensor wire and I think mine was a 220 or 230 what ever comes with an orion motor.
I did dremel a bit of the sides of the wire tunnel so the 3 motor wires could sit flat on the bottom and the sensor wire could also fit.
Just incase you all don't here it enough good job on the new truck and thanks for all the good set up info and I really liked checking out the tuning guide I thought it was very direct and simple to understand
#1688
@ Ryan or Casper I tried a few different combonations with the rear shocks. I tried to use 32.5 oil with both red and orange springs but ended up back at the 2 hole #55 30wt. and orange springs.
It feels to me like the dampening is a bit soft and the rear compresses and rebounds a little too quick and with the 32.5 it feels like there is a bit too much pack.
I ran out of time yesterday and had to go back to your setup for the main.
I feel like the front is locked in but the rear is a little unsettled
***My question is have you tried anything with heavier oil and a a larger hole or more holes in the piston?
#1689
Tech Prophet
#1690
ok, im not gonna wait on the 55 pistons to come in so im just gonna build them stock and then i can swap it over after i glue up the 55 pistons so since the emulsion shocks seem to be the ticket...anyone got a thread to look at or a vid to watch? I did a search and didnt see anything on here...
#1691
Tech Prophet
http://www.youtube.com/watch?v=QvwmH-Rfwik
#1694
I just finished it as a roller need to put in electronics. What size wire does everyone use I had run 10awg but need to get longer wire. I may get 12awg. The hobby shop said run 10 for less heat issues but its bulky. I had very tight shock caps as its been noted but got them on with pliers. Set them up stock with #3 and 4 pistons going to pick up some 32.5 and 30 shock oil. I bleed per the video had one that just would not give me that 1-2mm rebound but going to rebuild later with # 55's
#1695
Youll be happy with the sct pro.Its an excellent esc for the money.Do yourself a favor and get the program box because its a plus to be able to fine tune at the track.Any questions on the esc just pm me.
