On-Road Track help
These flat disks are enough to upset the car without causing it to flip over.
Z
These are what we use and work very well. Painted them red and white.
http://www.agrisupply.com/Plain-Mm-S...96/&sid=&eid=/
#20
how bout just a 90 degree elbow down into the track or 3 making a 270 into the pipe behind it
#21
Why is everyone so afraid of corner dots? My home town track is about 95% against using them
Pro corner dot:
Cars take less damage then running into barriers
Easy for track setup and change
Cost
Improves driver skill
Against corner dot:
Sometimes getting dots to stick sucks
unfriendly to lesser skilled drivers
Another option is to get the smaller corrugated pipe and use that for corners/end pieces.
Pro corner dot:
Cost
Against corner dot:
#22
http://http://www.stormerhobbies.com...ns&pn=LOSB1013
What about Losi dots. They are smaller but you can use more than one. They are inexpensive and are not supposed to upset the car as much as other dots.
My club uses road rails and I have yet to roll my car on the dots included yet.
#23
Look at the pics thru out this thread
http://www.rctech.net/forum/alabama-...e-alabama.html
Cut rail material to make the edges into a "Y", then bent a swimming noodle around it to create a radius. The noodles are forgiving, bright, and around $1 each. They last quite a few races before needing replaced
#24
You could find some hose that slips over the pipe. Just bend it to the radius that you want and stick it on another pipe.
At our indoor track we use flappers made from 1/4" LDPE sheet. The the plastic company cuts up a 4'x8' sheet into 3" wide by 8' long strips for about $120 including the material.
#25
Make your own "dots of doom".
Start with 1/8 "hardboard", cut out a 20" circle. Drill a 3/4" hole in the center. Use a jigsaw to cut out a wedge(pizza slice) of about 2". Pull the cut together,attach to itself and your done. A few bucks a piece, and last a few years. Thats what we use for asphalt and carpet.
#26
Roadrail is panned by most for the same reason, there's nothing to prevent cars crossing lanes and the shape helps to jump cars over the barriers.
Flappers are the best solution because it won't stop the car like a solid marker would, but they do push the car off line losing a lot of time without needing to be marshalled because your car isn't stuck or upside down.
#27
Attachment 1023392
Heat up a piece and bend it.. We use a rolled up firehose and place it it the middle to keep it in place..
#28
#29
Attachment 1023392
