New VBC Flash-04 F1
#124
FYI to all VBC flash 04 owners....
Parts are available (including 200mm wide conversion) and some other red bling
http://www.vbcracing.com/collections/vbc-flash-04-parts
front end looks interesting...
Planning on picking up some front end spacers, extra turnbuckles, and front arms just in case.
#125
chuck
#126
I got to run my F1 for the first time on a fairly high bite carpet track with some technical sections in it.
All I got to say is WOW!!
This thing was great!
#129
Two of the four have broken the rear axle right where the diff is pinned. The steering turnbuckles seem to be soft as well.
The car does go together well.
#130
#132
The stock rear body post mounting holes don't really mount up well with the F60. What we've done is replace the 3mm x 6mm button head screws that hold the "Front suspension support" (step 17), with 3mm x 10mm set screws glued into the upper deck mounts (step 14), and use the rear body posts as nuts to hold the graphite upper deck (step 17) in place.
#134
#135
I noticed this too so I made new plates that clear the body.
However I preferred to move the body posts to the forward hole, using the set screw method and spacers. It's a good location on the body and still makes it easier to remove the battery.
For me, I need to loosen or remove the 2 screws that secure the shock mounting plate in order to get my battery out easily. Having the posts there will make this more difficult.
