Hyperform Racing
Old 11-08-2005, 03:27 PM
  #931
mymax's Avatar
Hi Lino,
Just to let you know that I received the order today...Just in time for my big race.....
Don't worry I will let you know how it went.
I will send you tonight an order by e-mail.
Thanks,
Robert
mymax is offline
Old 11-08-2005, 04:14 PM
  #932
John Tag's Avatar
Trader Rating: 42 (100%+)
Where's Ed been...Stuck in the Pickle jar..
John Tag is offline
Old 11-08-2005, 07:07 PM
  #933
Hyperform Racing's Avatar
Originally Posted by mymax
Hi Lino,
Thanks,
Robert
Wow, that took long enough... What's up with that? I got your email order... No problem... Good luck at the race also...
Hyperform Racing is offline
Old 11-08-2005, 07:08 PM
  #934
Good talking to you today Tag. Hope to see you at the champs!
Old 11-09-2005, 02:45 AM
  #935
Originally Posted by cyrrus
Hey guy's the car is running great. (well almost) some minor tuning it should be great and my driving has to get better too to take full advantage of this sweet machine. last weekend was a fast flowing tack. this week should be tight but we never now till we get there.
Well the set up i'm using is pretty much the stock set up mention on the website.
I beleive it's
10 degree front blocks
1 degree of camber
-1 of toe
not sure the thickness of the t-bar.
or the front springs.
i'm using a black spring on the mono shock
and can't remember the oil wieht in the shock
i'm using 75 or 80 weight oil in the tube
front pink and grey rears
monster stock (every one in the club runs the same motor as it the club 12 scale motor)
100 spur with a 27 pinon
our track is alway different from week to week.
out carpet is old so it a low bite track.
Also running the battery rear
and running angle servo.
I found out last weekend that my tbar was not tight enough in which was giving me my steering problems. doh!
Looking for a bit more steering and more rear traction and ideas
I got to figure out gearing for this car how to use it to my advantage.
Hmmm, the tbar thickness and front springs are very important to the cars performance. Make sure you have 0.075" tbar and 0.020" front springs. The weight is your tubes sounds way to light. Try Trinity purple or red stuff. If you have a set of purple front tires, throw those on and see how they run. I believe black is a very very hard center spring. You may be compensating for the tbar thickness and or front springs being off the mark. You should be in the silver, blue or red range with 50wt oil. How large is your track? With a monster I usually roll out at 1.6 inches with GP3700 cells and 1.55 inches for the IB3800s.
Old 11-09-2005, 05:48 AM
  #936
CarlosG.'s Avatar
Trader Rating: 12 (100%+)
The black spring is actually softer than the green/olive spring.
CarlosG. is offline
Old 11-09-2005, 06:11 AM
  #937
Did someone say pickles?? we gotta keep pickles out of that pickle jar...
Ed you coming on Saturday?
Jarrod Langlois is offline
Old 11-09-2005, 09:01 AM
  #938
I'm thinking of the wolf black spring which is very heavy for a tbar car. If I remember correctly, it's in the area of 20lbs...
Old 11-09-2005, 11:40 AM
  #939
Default Uk set up
Originally Posted by radio_car_racer
Hope to use it before Teesside. Post your setup here and I'll give it a run before hand or pm if it's top secret
This is how I ended up running at Crewe
Front
5 Deg reactive castor
1.5 deg camber
1 deg toe out
Castor middle
ride height 3.5mm
20 springs
Parma purples 3/4 additive (CS high grip)
Rear
Pod level
.63" T bar
green spring, 25wt oils
tubes CRC heavy tube lube
ride height 3.5mm
Full additive (CS high grip)
Shell CRC courage
Going to try thick t bar this weekend, don't know about Teeside though depends what they've done about the bumps.
See you next week
Jason
jasonb is offline
Old 11-09-2005, 08:35 PM
  #940
CarlosG.'s Avatar
Lino, have you any t-shirts made up with the Hyperform logo on them? I am just curiuos.
CarlosG. is offline
Old 11-09-2005, 09:12 PM
  #941
eforer's Avatar
Wolfe black spring is 17lbs. I'm not sure about sunday, there were some complications and meg ended up back in the hospital early this morning and is hopefully being released tomorrow. If she's doing better by the weekend I can make it, but if she's not much better than she is now no way.
eforer is offline
Old 11-09-2005, 09:58 PM
  #942
I just ordered a bunch for the team. I want to see how they come out before ordering a large amount for the general public.
Old 11-09-2005, 10:00 PM
  #943
Ed, the race is on Saturday... Bummer about Megan.
Old 11-09-2005, 10:05 PM
  #944
eforer's Avatar
This hole thing has wicked sucked. I'll send her your best.
eforer is offline
Old 11-10-2005, 05:45 AM
  #945
is there any way to check the rate of the springs. also I was going to pick up some new front and rear springs. All they have are crc stuff(95% of the club race carpet knives) would these springs work too.
cyrrus is offline
