Tamiya XV-01
#166
So, I finally got around to putting on the longer shock ball-ends. I had to put some stop-screws into the bottoms of the front suspension arms to prevent the turnbuckles from hitting the chassis on full droop, but otherwise everything worked out pretty good. I lowered my body a bit and I'm really digging the stance! Not as slammed as I previous had it, but still looks the part. The added ground clearance will be really nice the next time I hit the dirt.
At the same time I changed the oil in my shocks and found it dirty after just one run. But, like the idiot that I am, I ended up putting 30wt oil into the shocks, thinking that's what I did originally. NOPE. Originally I used the kit oil, which is 900cSt, or about 70wt if I did my Google right. So now I have pretty bad bounciness, as the stock springs are overpowering the dampening. I'll be ordering some heavier oil tomorrow.
That reminded me of the new offroad spring kit Tamiya is releasing: http://www.tamiyausa.com/product/ite...oduct-id=54465
Anyone know where the stock springs fall on the spectrum. Also, how do the stock springs compare to the Tamiya onroad spring kit?
#168
#169
Question regarding off road running and a spool.
I've just picked up the XV-01TC PRO kit and the extra guards. I'm planning on running it off road.
I noticed that the kit came with a front direct-coupling (spool). Does anyone have any experience with running a spool in an offroad "rally" car? Should I got and get another gear diff instead?
Any advice?
Any advice?
#170
Any advice?
Any advice?
May I ask why you did that, though? The non-TC comes with extra protection from the elements, which the TC does not.
I don't have much experience with a spool offroad, but you can probably just get another XV-01 diff to put up front for cheap, no?
#171
Any advice?
Any advice?
#172
Hey all,
What kind of diff oil are ppl using. I haven't built mine yet but it will be used mainly on dusty tarmac (streets/parking lot) and on occasion dirt gravel
#174
This cracks me up... we have guys buying the regular XV-01 who try to convert it to full TC, and you bought the TC to run offroad
I did weigh up the option of getting a normal XV-01 kit (couldn't get my hand on the PRO), but the options available in the TC PRO (suspension, universals etc) really swung my decision in that direction. The TC PRO was 1000 yen more expensive than the normal kit. No tyres or body, but I have those already. The belt covers and "mud-guards" parts tree cost me an extra 504 yen so it wasn't that bad.
Added bonus is that in the past I've run both a TA05R, and a TRF416... so I have plenty of spare parts with regards to the suspension arms.
#175
#176
Ha, yeah I don't tend to do things the way "normal" people do it
Well, build it, then take some pictures and show us
#177
In the shocks, I found that with my white trf springs up front and blue in the back, the oils of choice were #1200 front and #900 back. This is an on-road setup.
#178
Thanks!
yeah i have a ta06 and run heavier oil up front, but wasn't too sure on the loose gravel and low grip dusty tarmac
I use the stock #900 in the back diff. In the front I'm still testing, tho it progressively got better by going up from the stock #900 until current #60.000
