How do I set up a HW xtreme stock for blinky??
Make sure you have a battery plugged into the esc and switch the car on, I'd advise having the car sitting on a car stand or the pinion removed before you do so.
Open up the software on your pc, click on the Firmware Upgrade button (if using the latest software) then select 508_No_Timing from the choices of upgrade software and then click on the "Upgrade" button at the top.
Remember to calibrate the esc to your radio after setting it into blinky mode.
Once all this is done you can just use the programming box to change the settings such as punch & brake strength without the need to connect it to your pc again.
Hope this helps.
Cheers
Rob.
Any time you make changes to the hobbywing speedo you should/must recalibrate with your radio. This seems to be the biggest problem for people with blinky 508 software. If the speedo does not see neutral from the radio it will not blink.
Where is the no timing at?
#20
Didnt see that download .i feel reall stupid right now.
#22
Im on the usb link. Box is saying connecting to pc.
#23
Firmware upgrage is up right now
#25
Got it thank you. I felt very stupid. Not blinking yet but not in the car yet.
#29
Check out the HW just stock, it's like $50 online and I know my LHS has them form $70 but if you only race stock it's perfect. Pretty sure it can handle up to a 9.5t, can't go wrong especially with the latest firmware it's all you'll need. I have one for my backup just in case but think I'm going to start using it for my primary
