rear one way??
rear one way??
ok guys, ive been just a basher for about 20yrs, i just started racing offroad about 4 mnths ago and now im 2 races in to my onroad career, my question is this, i hear people complain about not likeing a front oneway because of rear wheel braking, well i used to race motorcycles for about 5 yrs and raced legends cars as well, and in that along with real cars about 80% of your braking is done with the front wheels, so has anybody ever tried a oneway in the rear? seems to me youd get benefits of a one way but still get front braking and no worries of ass swinging around. anyone think this could work? i realise this post could make me look really dumb, but i cant be in the know unless i ask or try it!!
rear one way
my guess is the big companys that have a lot of r&d time and money have most likely tried it and did not like it. with all the traction you can generate on carpet, i wouldn't be surprised if the rear end didn't come around anyway when all the weight shifts to the front in a hard turn.
I too have wondered the same thing, I come from a real race car background and we ran open rears, either a locker (which would act just like a one-way) or a gear drive unit which would send the power to the wheel that was getting the traction. We ran only oval but it might work? I might try it in my xxx-s this week and see what happens. Diff up front and one-way in the rear.
yeh, i am gonna try it in my 414, i dont even have to change the diff, it has a pully that i can switch to a one way pully.
wouldnt it push on power alot?
why would it push on power, on power should be no different than normal, i thnik?
wouldnt it be the same as tightening ur rear diff and doesnt that make the car extremely loose?
If you used a oneway diff in the rear, then yes it would make the car understeer because it would basically be a locked diff under power.
But if you put a oneway pulley in the spur layshaft in a belt car, and many belt cars have these it wouldn't make any difference on power only off power
Mike, I know on the 415 the front one way will fit in the rear, it just needs some shimming and take the o-rings out of the cups for a little more clearance. I did not get a chance to try at the time due to no front diff. Let us know how it goes with the 414. Also Mike we are switching back on-road to sundays, just not sure when. Keep in touch so I can beat on you and John closer to home :P
With 4 wheels powering out of the corner I don't think there will be an issue with a push. If anything you would break a tire loose more often than not. *obligatory machismo* ..Or like a real man you'll just hang on to the throttle and pull it out *end obligatory machismo*
yes, as i thought about it more, it would lock up, this is were im at now.
yes mason, i spoke with tom, im gonna run b&b next weekend, and i think toms going sunday onroad the following week, and im there!
p.s. hope you feel better.
It might work.. Try it and let us know.. But with what i know about "real" cars they tend to push with lockers and a one way would work like that when on power(last time I checked not many people wanted a huge push exiting corners)That is what i would think would happen on exiting a corner,I'm not sure on how the car would rotate while in the corner..damm I'm going to think about this night now..
This was a trick we used a lot in the old off road days running Optima Mids - as they had interchangeable diffs.
On loose tracks it was superb, very stable under braking and good power down grip.
Not sure what it would be like in touring cars but I think it would be worth trying
